ANOTHER OVERHEATING BONGO, HOPEFULLY SORTED
- Peg leg Pete
- The Great Pretender
- dandywarhol
- dandywarhol
Dannyboy
Hi Dandy
The thermostat is in-fact the other way up from the pic. As the thermostat opens to permit the flow from the radiator to cool the system, it closes off the bypass (the pipe running from the head, to the thermostat; behind the alternator).
We think that it is likely that the thermostat is constantly opening and closing to maintain a constant coolant temperature, according to driving conditions (up hill, down hill, speed, load in vehicle, etc.).
We think this results in a steady minor flow though the radiator that results in the lower pipe being cool to warm but not hot, as the radiator is very large and efficient, as it is designed for a hotter climate.
- dandywarhol
Dannyboy
A minor, random input from me. I was thinking about the little hole in the thermostat, which seems to have a simple gravity type valve (little ball on a stick!) device in it. I know it was mentioned earlier tat it was for allowing trapped air through, but there is another possibility. Could this be intended to allow a small flow of water so that whatever temperature the water is reaching as it warms up after engine start, that temperature is experienced all round the thermostat (not just on the 'upstream' side) so it can respond in a smoother more predictable fashion. If the flow is sluggish due to a blocked rad, then it might explain why drilling 3 holes helps to achieve the desired result in allowing the thermostat to sense the rising temperature, open as it should, and prevent a boil up.
Cant really think what the little valve is for unless to stop blow bakc of cold water coming (for some reason I cant fathom) from the far side of the thermostat.
Any thoughts?
Any thoughts?
- dandywarhol
It won't Mike - the "jiggle pin" is there to allow air past but whenever coolant gets to it it closes as the "ball" part of it floats. It's only purpose IMO is to be used in the filling process and allow coolant past and air out of the system
Dannyboy
Hi mikeonb4c
We think that the little toggle valve is there just to let the air up and out of the bottom hose when filling etc, as as soon a flow of water goes up it closes off the valve.
if you squeeze any of the main cooling pipes when the engine is off you can hear the toggle valve close.
We assume that as the water pump is constantly pulling the water through the system it would be impossible for the flow to pass down past the valve to the lower pipe.
Dannyboy
Well there is indeed a problem, but... the comment was more to explain why the flow from the bottom pipe was cool, not hot, rather than the system working correctly.The Great Pretender wrote:So Dannyboy, if the system is made for hotter countries and can cope with anything we can through at it in the uk, why the head problems?
If the hottest part of the engine is where the problem is, its down to a cooling problem, and size here aint important, design is.
Hope that makes some sense, though looking back over all that I'm not so sure.
Dannyboy
Pete
