ANOTHER OVERHEATING BONGO, HOPEFULLY SORTED
- haydn callow
No Peter, not from what Haydn is saying although it did in the Townace but then it didn't have the bypass circuit. Being a novice to the Bongo I'm taking Haydn's view that the rad only plays a part when hot, at face value. What I'm trying to ascertain is why do some Bongos express this overheating problem while the majority don't. Many UK owners of the Townace which was also made for the Japanese home market and lower speeds, complained of cracked heads and silted coolant pathways. The latter seems to be common with those experiencing problems with the Bongo overheating. Therefore, I'm proposing that the issue is to do with the history of certain vehicles and the fact that the heads may be suffering from 'clogged arteries'. In some cases this may be helped by improving the coolant flow by adding holes to the stat. So I'm not advocating the rad plays an active part in all this but am coming down on the side of those who add holes to the stat where suffering from overheating.
Why is any car made that can go over the speed limit? - better acceleration?haydn callow wrote:cannot agree that the bongo was not ment to cruise at 70 plus MPH . If that were the case why will it do the TON??
Done over 100,000km in mine without modified stat in all conditions from snow in the highv Alps to the Med coast in mid summer heat.
So far I've had the following cooling probs:
1st winter (2005) bottom hose froze solid leading to overheating (no circualtion)..cure...let it warm through and refill with coolant.
April 2006...Water pump failed and had to be replaced...engine 'boiled/cooked.
Cause: Belts overtightened on service (failure after aout 5.000km)
Cure..replaced water pump..bled engine (without handbook).
August 2006...radiator leaking from plastic top...tried radweld without reult...replaced radiator..bled system..all ok
Guage reads at about 11.30 (a smidgin to the left of vertical) always has done.
Water has tended to be bunged in rather than coolant...only checked annually in spring...which is probably a mistake!
Hope this is of use as an example of 'normal' in a high use bongo.
cheers
H
cheers
H
I like the idea of clogged arteries.
This could eisily happen if a vehicle is left standing for long periods when impurities in the water system and oxidisation may well settle and form a cement like sludge.
If there was any air in the system this would actually make matters worse.
It may explain why some vehicles may be more prone...and of course simple flushing won'tshift it...but using the engine will...in lumps which may cause temporary blockages..
just following logic???
H
H
- Peg leg Pete
- haydn callow
- haydn callow
- haydn callow
