white exhaust smoke
dreamwarrioruk
Post by dreamwarrioruk » Wed Feb 28, 2007 6:13 pm
i dont have the problem well not since i repaired it last september
mancunian
Up date to white exhaust smoke
Post by mancunian » Sun Mar 18, 2007 6:35 pm
Have had the head replaced as old one was cracked on the front cylinder. Now NO smoke and much more POKE.
Thanks to all for their wise words and help
Mark
Peg leg Pete
Post by Peg leg Pete » Sun Mar 18, 2007 6:37 pm
Glad you have got it sorted, not too costly I hope :wink:
Image Pete
mancunian
white smoke
Post by mancunian » Sun Mar 18, 2007 6:42 pm
Not a penny, it is still under the 3 months warranty from the dealer. Who was extremely helpful in sorting the problem, though they can't sort the rear door central locking or not locking as it is. It locks via the key, but not remotely. He can't get a signal/voltage reading at the tail gate connectors.
Mark
Post by mikeonb4c » Sun Mar 18, 2007 6:51 pm
Make sure the cooling system is working well and decent throughflow to the radiator as you've not said what might have casued it (could be an old incident mind you). Glad its fixed OK :lol:
Peg leg Pete
Post by Peg leg Pete » Sun Mar 18, 2007 7:02 pm
Mike you are now on the coolant crusade, just like me :wink: can't be emphasised enough!!!
Image Pete
mancunian
Post by mancunian » Sun Mar 18, 2007 7:25 pm
Is there an inherant cooling problem with Bongo's then? My old Renault Scenic Diesel (124,000 miles) never gave a moments problem with the cooling.
Peg leg Pete
Post by Peg leg Pete » Sun Mar 18, 2007 7:28 pm
Coolant needs replacing and sysytem flushed every 2 years, system then needs to be bed correctly to avoid overheating problems, due to airlocks in system.
Image Pete
Post by mikeonb4c » Sun Mar 18, 2007 11:21 pm
Cracked head (like yours was) on a Bongo seems to happen from an overheating episode, nearly always connectted with a problem in the cooling system. Old pin-pricked rad hoses, sludge blocked rads. etc. are the usual causing (oh and poor bleeding after refill - they have to be carefully bled to avoid airlocks). This is why we suggest you check it wasnt a colling system problem that caused the head problem.
Good luck
Mike (and Peter), The Coolant Crusaders 8) 8)
