Alternater
slasher
Alternater
Post by slasher » Mon Mar 12, 2007 5:34 pm
Help my alternater is giving out 16volts,and the battery is charging up to this.Anyone any idea,or had this befor.Checked the voltage to the field wires 0.I supose that if its not getting the battery voltage it will give out as much as it can.
Slasher
dandywarhol
Post by dandywarhol » Mon Mar 12, 2007 7:05 pm
Sounds like a dodgy regulator in the alternator slasher - best get it sorted soon or you'll fry the battery :?
slasher
Post by slasher » Tue Mar 13, 2007 3:58 pm
After trawling through past entries came on a symilar problem.The answer was given by Pipin who pointed out that the meter needed checking before we comdemed the alternater and on taking his advice it was a low battery in the meter and there was nothing wrong with the circuit.
Slasher
pippin
Post by pippin » Tue Mar 13, 2007 4:48 pm
There's three pees in pippin, if you don't mind!
Glad to have been of technical service.
Post by mikeonb4c » Tue Mar 13, 2007 6:01 pm
A case of PPPick Up a Pippin (for those old enough to remember the ad :cry: )
Woops- wandered off thread again :?
