V6 breakdown symptoms
Mrs Feynmans Bongos
Re: V6 breakdown symptoms
Post by Mrs Feynmans Bongos » Thu Nov 13, 2025 8:36 pm
UPDATE
CAMBELT was indeed found broken under the cover, also loads of oil there. He couldn't really say if this was clean oil (since my post breakdown top-up) or dirty/mixed.
He wants to first just put a new belt on, spin the camshaft by hand whereby ?check pistons have compression? He says this will rule out damaged/bent valves.
I had sent him http://designrocket.wpengine.com/wp-con ... g-belt.pdf wherein we read "this engine has been identified as an INTERFERENCE engine in which the possibility of valve-to-piston damage in the event of a timing belt failure is most likely to occur"
So not a CLEARENCE engine after all?
Even if compression seems ok, he says if will definitely need a new CAMSHAFT SEAL, besides the Pulleys/Seals in the Belt kit. He wonders if oil leak caused timing belt to fail, but belt seems to me the "cause" not the "effect" given it was low on oil.
Any more thoughts, advice appreciated!
Post by g8dhe » Thu Nov 13, 2025 11:12 pm
No its a non-interference engine - J5-DE - Only if the head has been skimmed or otherwise altered could there be a problem as the clearance is minimal. If you search on here you will find other references to it not being a problem. However if a valve should drop because of a broken stem then every engine can suffer damage!
Post by Doone » Fri Nov 14, 2025 9:41 am
"He wants to first just put a new belt on, spin the camshaft by hand whereby ?check pistons have compression? He says this will rule out damaged/bent valves."
Yes it will.
That explains the oil leak was most likely from the cam seals and/or crank seal.
Change all 5 seals, hydraulic adjuster, 2 guide wheels, water pump and belt.
And change the thermostat while its dismantled.
It's a small extra cost that can save a lot of labour if changed on it's own.
Mrs Feynmans Bongos
Post by Mrs Feynmans Bongos » Sat Nov 15, 2025 6:29 pm
Water pump and Thermostat now ordered too!
(New but not sure gaskets included. Should originals be ok if replaced with care, or best change them too?) Can be returned within 30 days, in case she doesn't make it..
Geoff, Allan, you guys are fab, so supportive [-o<
Post by Doone » Sun Nov 16, 2025 9:37 am
Water pump & thermostat gaskets are usually in the kit.
It could be sensible to change the rocker cover gasket as it's likely to be worn out too, if it's as old as the other parts. If it leaks, the oil can affect the plugs.
Mrs Feynmans Bongos
Post by Mrs Feynmans Bongos » Mon Dec 22, 2025 11:23 am
Seems to be running well again :D
Cambelt (broken), camseals x5 (one had failed), pulleys, water pump, thermostat, also rocker seals and Alt/fan belt (advised cracked/looked poor), plugs, fuel filter.
8h labour charged, plus I sourced all parts c.£400.
It appears a cam seal had failed, leaking oil onto Cambelt which failed. Redosed with Blue Devil "Oil Stop Leak".
AVA's Timing Belt help sheet states INTERFERENCE engine, 7h labour https://mazdabongo.com/timing-belt-info ... v6-petrol/ yet actually CLEARANCE?
Thanks for fab advice yet again, Allan and Geoff =D>
Post by g8dhe » Mon Dec 22, 2025 3:47 pm
Yes definitely a clearance engine, someone on the forum did check the piston head level when the heads were removed to prove it.
