Front 4x4 wheel bearing
Mordusy
Post by Mordusy » Thu Jun 19, 2025 5:41 pm
Any one replace the front wheel bearing on 4x4 bongo ?
Are the wheel bearings all the same across the models ?
Any hints on where to get the bearing and doing the job.
Thanks.
Re: Front 4x4 wheel bearing
Post by Doone » Sat Jun 21, 2025 8:41 pm
Does this post help - there are links in it: https://igmaynard.co.uk/bongo/forum/vie ... p?p=726450
Mordusy
Post by Mordusy » Mon Jul 07, 2025 10:01 am
Thanks but I don't think that helps me, Im just trying to make sure I order the correct front wheel bearing for a 4x4 as all I can find is post saying the front 4wd bearing is different than the 2wd one
Post by g8dhe » Mon Jul 07, 2025 11:33 am
If you look up the 4x4 diagrams for the wheel bearings https://www.lushprojects.com/bongoparts ... no=.html#5
then the table top left opens up for the part # S10H33047 or S10H33047A
Google the part number https://www.google.co.uk/search?num=100 ... =S10H33047
and you have sources.
