Help with Car Audio System Wiring
Bongo-Bean
Post by Bongo-Bean » Mon May 05, 2025 9:41 pm
New Bongo owner here.
I know this topic has been brought up many times before, but I have searched the forum and can't seem to find the answer to my specific problem.
I have recently purchased a Bongo (2006 model) and the previous Japanese owner had fitted a Pioneer Carrozzeria AVIC-MRZ66 GPS/audio system which I want to replace. I have pulled out the unit from the dashboard to have a peek at the wiring behind (please see attachments below.
I want to replace it with another audio unit, probably something more simple (not really bothered about GPS).
I have read on a few post I probably need a wiring harness. Not sure which one I need though. Looking at my existing wiring do I need to change or modify anything else?
Any help will be greatly appreciated.
Thank you.
Re: Help with Car Audio System Wiring
Post by g8dhe » Tue May 06, 2025 8:36 am
You need to follow the wiring back to the original Mazda connector which has the vehicle wiring loom behind it, normally the original loom is covered in a foam wrap behind the plug. Then you will need the relevant Mazda to ISO conversion wiring - its possible that is what you already have, or at least a homemade version of it.
There are two types of adaptor depending on year;
from 1995 to around 2000/2001 it is PC2-10-4,
after 2000/2001 it becomes a PC2-78-4
both types are available on ebay,
https://www.ebay.co.uk/sch/i.html?_nkw=+PC2-10-4
https://www.ebay.co.uk/sch/i.html?_nkw=+PC2-78-4
Bongo-Bean
Post by Bongo-Bean » Tue May 06, 2025 8:21 pm
Thank you for your reply Geoff.
I will investigate further.
