Refurbished fuel pump installed, no start
Moderator: Doone
Dodo23
Post by Dodo23 » Thu Nov 21, 2024 12:26 am
I have read through a bunch of threads, but couldn’t find a solution that would work for me. Fuel pump was leaking and also seemed to have trouble pulling fuel from the tank after running for 10-15 minutes (had gotten progressively worse). Anyways, got a refurb fuel pump and my mechanic friend installed it, he didn’t touch the timing according to him (could there be an issue here?). Now when we engage the starter there is flow from return line, but no start. It does fire up if I spray brake cleaner in the intake, but blows bluish smoke. We had it running for 20 minutes or so didn’t see any improvement. I took it for a drive lacks power and still blows smoke.
It used to fire right up with the old fuel pump and ran pretty good before we swapped. Also glow plugs were replaced not too long ago.
Any ideas?
Dodo23
Re: Refurbished fuel pump installed, no start
Post by Dodo23 » Fri Nov 22, 2024 12:25 am
Just took the glow plugs out, reinstalled them on the rail, grounded them to the block individually and switched the power on and all of them glowed red hot.
Dodo23
Post by Dodo23 » Tue Nov 26, 2024 6:40 am
Anyone?
Post by Ian » Tue Nov 26, 2024 8:52 am
It's above my pay grade this one. Where are you based? We might be able to find someone local who knows about such things to have a look.
Post by Doone » Thu Nov 28, 2024 9:47 pm
If its blowing blue smoke I'd double check the fuel pump timing?
Allans garage closed. Try PGS (Plymouth Garage Services) or Mayflower Auto Services Plymouth
Dodo23
Post by Dodo23 » Fri Nov 29, 2024 2:43 pm
I am in Canada. How do I check the fuel pump timing?
Post by g8dhe » Fri Nov 29, 2024 4:00 pm
Several relevant threads on the forum see here: https://www.google.co.uk/search?q=frien ... ump+timing
