Mystery wire under centre console
- Apprentice Bongonaut
Any idea what wire connected here? A section of it was attached but tore off. Wasn't going anywhere. Looks nasty here generally. Any idea what can cause this?
- g8dhe
Re: Mystery wire under centre console
Not quite sure where we are looking but any chassis connection will be a Black wire, but I can't quite work out the context around the image!
Apologies! Camera was in close up mode. Contextual pic attached.
- g8dhe
Ah you may have had a console with the TV and DVD player in the rear, in which case it would have been the chassis connection in addition to a hefty loom running from the controls (accessed from the rear) running back down to the front of the vehicle. Whatever there isn't a standard vehicle connection at that point it will only have been some optional add on.
Thanks! As long as there's nothing that's supposed to be there.
