Remote Key Fob Questions
thomp1983
Post by thomp1983 » Fri Feb 10, 2023 3:35 pm
Hi all,
My Bongo has come with the following remote key fob which seems to be factory issue.
The lock button felt stuck so I took it apart last night and found a, there's no battery in it and b, the microswitch for the lock button is missing.
First does anyone know what type of battery these take? There's a picture inside the case saying 7J29A which I assume is a Mazda part number, does anyone know what type of battery this equates to, I'm guessing a cr20 series battery of some type.
Secondly has anyone replaced a microswitch in these? I found something on ebay that looks similar last night but will need to wait till I'm back at work tonight to do some measurements and compare to the micro switch I've found.
Chris
Allans
Re: Remote Key Fob Questions
Post by Allans » Wed Feb 15, 2023 8:37 am
Usually the battery size is marked on the fob. Sometimes it's trial and error. See screenshot as example. (I've removed poster's names for privacy, as they're not on the forum.) I've not heard of anyone replacing the microswitch. But plenty have replaced the fob.
nth
Post by nth » Wed Feb 15, 2023 10:40 am
I had the same fob on mines till i changed it to an aftermarket alarm but just opened it & it has a CR2025 in it.
95 2.5d 4WD AFT
thomp1983
Post by thomp1983 » Wed Feb 15, 2023 2:09 pm
nth wrote: Wed Feb 15, 2023 10:40 am I had the same fob on mines till i changed it to an aftermarket alarm but just opened it & it has a CR2025 in it.
Dont suppose you still need the fob do you? And out of interest what aftermarket alarm did you go to?
Chris
nth
Post by nth » Wed Feb 15, 2023 2:37 pm
I went for a Toad Ai606 Cat1 alarm which now does my central locking. Was going to hang onto the fob incase i want to remove the alarm in the future & revert back to standard if i get rid of the van.
95 2.5d 4WD AFT
thomp1983
Post by thomp1983 » Sun Feb 26, 2023 2:15 pm
Hi all,
I fitted the microswitch I found on ebay yesterday along with a new CR2025 battery and the fob now works.
Thanks for the advice
Chris
Post by Bob » Sun Feb 26, 2023 5:03 pm
Nice one. 8)
