Driveaway awning
Moderator: Muzorewa
Snicole23
Driveaway awning
Post by Snicole23 » Sun Aug 14, 2022 10:38 pm
Hi all,
Can anyone recommend a good driveaway awning for a Bongo Friendee with a canopy attached? Does anyone use a magnetic strip at all, how have you found using it?
Kind regards :)
Re: Driveaway awning
Post by g8dhe » Mon Aug 15, 2022 8:41 am
You don't say which type of attached canopy you have some already have a slot(s) in the leading edge to attach a driveaway type to.
A lot of people have reported that the magnets don't work very well as soon as a breeze gets up, they start to slide and then any flapping dislodges the magnets.
Snicole23
Post by Snicole23 » Mon Aug 15, 2022 9:59 am
Ah, I naively didn't realise there were different types - ours has a Fiamma f45s canopy. That's helpful to know regarding magnetic strips - thanks! :)
Post by g8dhe » Mon Aug 15, 2022 10:45 am
Well the Fiamma 45 range has one or two slots in the leading edge;
that one has a single slot, the latest F45S has two slots one from each end;
Just run your Kader strip into one of them and the other side into the awning and your driveaway is setup
Snicole23
Post by Snicole23 » Mon Aug 15, 2022 2:09 pm
Ah brilliant! Ours is the second picture with 2 slots! This is really helpful, thank you so much! :)
Snicole23
Post by Snicole23 » Mon Aug 15, 2022 2:16 pm
Sorry! So to driveaway, you detach the Kader strip? Or the awning from the Kader strip?
Post by g8dhe » Mon Aug 15, 2022 9:37 pm
You pull the Kader strip out and then the vehicle is detached from the awning and you drive away, otherwise you would have to take the awning down to slide it out from the slot!
Post by Muzorewa » Tue Aug 16, 2022 7:48 am
Yes, as Geoff says, slide the Kador strip out which leaves the figure-8 attached to the drive-away awning but detached from the canopy, so you can drive off. It's common to place a couple of tent pegs by your wheels on that side before you move, so you can park back in almost the same spot to make reconnection easier.
