Hello All,
I would be interested to hear from anyone with a 2.5 diesel with a head or coolant mounted temperature gauge what readings are normally seen when going on the flat, long uphill and long downhill please.
Many thanks
Engine temperature readings
Clever people the Japanese.
Re: Engine temperature readings
Lots of discussions on this! Best to use a search like this one search.php?keywords=%22engine+temperatu ... mit=Search
- BongoBongo123
In short... Winter 89C and summer 93C averages. Can hit 97c - 100C for a very short time on a long climb
using a temp sensor on the back of the head.
They call me light foot.
Hello Gents,
Many thanks for your replies. Have you noticed if the reading drops much on a long down hill?
I installed a coolant level alarm for added peace of mind. It was simple to install. Two hours with tea breaks. You can find it on ebay without issues.
I also installed an 80p resistor from Maplins at the rear of the dashboard to increase the accuracy of the temperature measurement. It's a little more difficult, but it's still just around an hour's effort. A soldering iron is required.
- ever after.
There or there abouts, sometimes if you park it up in the summer the temperature will go up past 100° setting off the temperature alarm but it'll come down very quickly once you get moving againBongoBongo123 wrote: Wed Jun 29, 2022 8:43 am In short... Winter 89C and summer 93C averages. Can hit 97c - 100C for a very short time on a long climb
- BongoBongo123
It is likely to go down a bit downhill... a bit, maybe 5C ona 1-2miles downhill... but not excessively.. Afterall the engine must of got hot going up and then you are barely using any diesel or revs going down... but are getting radiator wind rush cooling the circulating water.
- haydn callow
If all is well and you should run with temps between 82 and 92C …….up big hills or towing loads then up to 100C
