Hi all, just found a leak from the water input pipe to the sink but can't really access it above the gas bottle to see where the issue with (JAL side conversion). Tightened anything I could but still seems to link when running cold water.
I've no idea how I access that to see what the issue is and fix it, any ideas whether I need to try to remove the sink and is this an easy job?
thanks all
Leaking sink
Hazzobongo
Re: Leaking sink
Mine has a dometic sink and tap and the connection to the tap is rubbish as it basically just pushes home and comes out if you turn the tap on, I use it by pointing the hose part into the pot I'm using then turn the tap on till I get another tap or mine would squirt water all over under the sink, taps about fifty quid on ebay.
If its the sink itself leaking just unscrew the plumbing underneath from the drain apply some silicon sealant and it should be good to go or visit a plumb centre and get another sink drain seal.
