1998 ford freda help, with front fan
fordfreda90
Post by fordfreda90 » Sun Mar 20, 2022 2:18 pm
good afternoon all
i hope someone can help me, quick brief i have read the thread about the front blower fan not working and i need some more help.
so i have a 1998 ford freda left to me when my dear friend passed away, he let it get in to a bit of a state so i am in the middle of a full refurbishment/restoration.
So far i have replaced the radiator as it was leaking like a sieve, new automatic gear oil, engine oil replacement and she ow runs sweet as a nut.
Then the deeper problems started... the windows working intermitantley traced to broken cable in door now sorted.now the fans front and rear are not working.
so i have followed all steps in the previous thread about stripping it down cleaning ect, applied 12v to the motor works great, went to earth 1 behind drivers headlight cleaned and polished so good earth now. the transistor/resistor thing under the drain hole is also good,but still no power, i've had the whole internal blower controls out to make sure its all plugged in and it is. my next step is relays i think.
so to the left hand side where the normal battery is there is 3 relays and to the right there is 2 relays, the 2 on the right seem to be the lighting relays as my little diy bridges turned the lights no and off..
im seriously stumped so if anyone can help that would be much appreciated.
thanks mike
Mike
1998 Ford freda 2l petrol with aft
Re: 1998 ford freda help, with front fan
Post by g8dhe » Sun Mar 20, 2022 5:19 pm
Welcome aboard!
Here you go diagram and locations for front air con climate control type - if your a manual slider variety let me know!;
fordfreda90
Post by fordfreda90 » Sun Mar 20, 2022 5:35 pm
@g8hde thanks very much for your help i dont know what mine is it has the hot cold dial a speed dial and face window feet position dial and a seperate ac button,with a seperate slider for air recirculation
thanks again mike
Mike
Post by g8dhe » Sun Mar 20, 2022 5:42 pm
Ah you have the older manual type of controls;
fordfreda90
Post by fordfreda90 » Wed Mar 30, 2022 5:30 pm
Well thanks to the schematics posted and my boss being an ex Audi master mechanic specialising in electrical systems he used the diagrams to solve my problem, and as it turns out I made a mistake and put one of the fuses under the steering wheel in the wrong place, haha.
Plus side i striped everything down put new resistor and relay in and cleaned and adjusted the fan itself and brushes ect so now it's perfecto thanks again for all your help
Mike
Post by g8dhe » Wed Mar 30, 2022 5:37 pm
Ah good news, yes its well worth cleaning the fans out they do suffer both water and particle damage as there isn't a filter between intake and fan!
