Windscreen Rubber
rchambers84
Windscreen Rubber
Post by rchambers84 » Wed Mar 23, 2022 8:52 pm
Evening all.
I've got what I am hoping is surface rust around the windscreen of the bongo behind the rubber seal so I'm going to take the windscreen out, repair it and have it re-bonded in. However while I'm re-fitting I want to replace the old rubber seal. Does anyone know the actual name for this or where I can get it from?
1995 AFT 2.5 D
Richard
Re: Windscreen Rubber
Post by g8dhe » Wed Mar 23, 2022 10:42 pm
Normally part of the replacement process is to put a new rubber surround on as it will have to have been cut to remove the old one when the cheese-wire cutter is inserted.
rchambers84
Post by rchambers84 » Thu Mar 24, 2022 9:02 am
Thanks, that what I was expecting
Just wondering where I can get a replacement as I can't find them online at the usual suspects
rita
Post by rita » Thu Mar 24, 2022 1:29 pm
Try this number on Google.
GA7B50894
rchambers84
Post by rchambers84 » Thu Mar 24, 2022 7:55 pm
Fantastic. Thanks
