Roof Bolts for roof bars
Bongo4ofus
Post by Bongo4ofus » Thu Jan 20, 2022 10:11 pm
I'm looking for help for a loose roof bar on my pop top 54 plate Bongo. I've fitted roof bars today but 1 of the bolts has come loose when fitting, meaning only 3 of the fixings are attached at the moment.
The top part of the bolt fixing is loose and the bottom part appears to have fallen into the roof. I've raised the roof however the under side of the bolt hole is hidden by the elevating roof mechanism.
I was wondering if anyone has had same issue and any solutions?
Re: Roof Bolts for roof bars
Post by g8dhe » Thu Jan 20, 2022 10:43 pm
These are the parts, but I've never had one come unthreaded;
Bongo4ofus
Post by Bongo4ofus » Fri Jan 21, 2022 9:31 pm
Thanks but I can't find an attachment or picture for what you mean?
Post by g8dhe » Fri Jan 21, 2022 10:35 pm
Not quite sure what you mean ?
The picture appears beneath the text, of the threaded bore that screws into the the flat plate on the underneath of the AFT.
Are you not seeing the picture ?
Post by Bob » Fri Jan 21, 2022 10:38 pm
Showing clearly here. :)
sotal
Post by sotal » Sat Jan 22, 2022 8:58 am
Not sure if this is helpful or not but no picture shows for me either.
Also the picture in Geoff's signature doesn't show any more either. (Hasn't done for a while)
I wonder if it's getting blocked by certain ISPs for some reason?
Randomly though, if I right click on the missing image placeholder and click on 'open image in New tab' then I can view the image perfectly. Which proves it isn't blocked. How strange!
sotal
Post by sotal » Sat Jan 22, 2022 9:04 am
This is what I see and what I see as the image Geoff has posted when I open it in a new window. Fingers crossed they show in this post!
Bongo4ofus
Post by Bongo4ofus » Mon Jan 24, 2022 10:13 pm
Thanks for that, the picture shows up in the last message.
So basically the bottom part of that bolt has fallen into the underside of the roof. I can't gain access to the underside of the bolt hole as the framework and mechanism for the elevating roof is in the way.
I was wondering if people knew a way around this or will I need to remove the shell of the roof?
teenmal
Post by teenmal » Tue Jan 25, 2022 1:15 pm
If you can get the proper size worth trying expanding bolts or anchors .
sotal
Post by sotal » Tue Jan 25, 2022 8:09 pm
I wonder if a rivnut would work in this instance?
Post by g8dhe » Tue Jan 25, 2022 10:39 pm
The flat nut has a plastic moulding around it which is part of the roof, so normally it just slides in from the inside edge as I recall, this is above the rails for the roof sliders.
rita
Post by rita » Tue Jan 25, 2022 11:37 pm
Bongo4ofus wrote: Mon Jan 24, 2022 10:13 pm Thanks for that, the picture shows up in the last message.
I would try toggle bolts .
Hazzobongo
Post by Hazzobongo » Wed Jan 26, 2022 9:48 am
Bongo4ofus wrote: Thu Jan 20, 2022 10:11 pm I'm looking for help for a loose roof bar on my pop top 54 plate Bongo. I've fitted roof bars today but 1 of the bolts has come loose when fitting, meaning only 3 of the fixings are attached at the moment.
Have you tried a 'magnet on a stick' type tool, I use mine constantly on my motocycle as I'm always dropping tiny bolts/nuts when getting at my engine, they usually come with different size magnetic heads to get into tight gaps and are extendable to reach into places.
Bongo4ofus
Post by Bongo4ofus » Tue Feb 22, 2022 8:57 pm
I'm waiting to hear back from Tim at Bongo Barn as he's removing a roof this week to provide some tips on how I might gain access. Fingers crossed.
