diagnostic box...mistake. bongo fire but won't start...
rongo
Post by rongo » Fri Sep 10, 2021 11:36 pm
Hi all
I am looking for some advice…
I made a problem with my bongo 2.5td, 3 weeks ago…
On the diagnostic box I connected the +B (switched battery voltage) with the GND (Ground)…picture below the connection i have made is the orange ligne.
I had 1Second of inattention and boom…
As the result I heard like a fuse blown…from that point I could not start the engine…it was working fine 10 minutes before this mistake…
I have done the diagnostic few times before with no problems…
In both scenario the engine fire but doesn’t start…
1-No feed to the glow plug
The fusable link from battery (tested for continuity) ok
glow relay ok.
2-feed to glow plug
Fusable link replaced with a 30amp fuse.
Glow relay replaced with a 70amp fuse.
I have checked the fuses all ok
-under bonnet fuses
-fuse box on the lower right-hand dash
Any ideas, solution or where to start looking for the issues will be really appreciated, thanks in advance.
LDON SE
BONGO 2.5TD auto 4WD 1996
SGL5
« Je ne sais qu'une chose, c'est que je ne sais rien. »
Re: diagnostic box...mistake. bongo fire but won't start...
Post by g8dhe » Sat Sep 11, 2021 9:12 am
The 30 Amp fuse middle row left will have blown this is the engine control circuit hence your problems;
Replace the original glowplug fusible link, a 30 Amp fuse there will immediately pop when the above fuse is replace!!! It has to handle a very large surge current in the order 60-100 Amps hence the reason for a fusible link and not a normal fuse.
rongo
Post by rongo » Sat Sep 11, 2021 10:55 pm
hi g8dhe,
thank you for your speedy reply...
just back home, went strait to change the fuse you advice to...
the bongo start strait away...
i have spent 2 weeks trying to figure it out
it took me less than 2 minutes, following your advice
i thought that i have checked all the fuse at least twice... but next time i will remove them one by one to check if there are ok...
lesson learnt...
(i have a Glow Plug Indicator flashing, i will open a new post once i read the error code...)
thanks again for your help...
LDON SE
SGL5
Post by g8dhe » Sun Sep 12, 2021 1:28 pm
If you have an error light flashing, give the vehicle a run and a couple of starts there is a good chance the ECU will reset itself unless you really do have another fault present.
rongo
Post by rongo » Sun Sep 12, 2021 7:27 pm
Hi g8dhe,
i will try this week....
Hope that the faults will desapear...
Thanks for the advice...
LDON SE
SGL5
