Top rubber for rear coil spring
Alkers
Post by Alkers » Mon Oct 05, 2020 9:38 am
Does anyone know where to source the rubber part that goes between the rear coil spring and the cup on the suspension mount? Getting a small bit of rust addressed and these rubbers are badly perished.
Re: Top rubber for rear coil spring
Post by g8dhe » Mon Oct 05, 2020 10:01 am
Nothing listed but might be worth calling Bongospares and Mazdabongo as they seem to have all the other suspension bits available ?
Alkers
Post by Alkers » Mon Oct 05, 2020 3:11 pm
g8dhe wrote: Mon Oct 05, 2020 10:01 am Nothing listed but might be worth calling Bongospares and Mazdabongo as they seem to have all the other suspension bits available ?
Bongospares can't get them new and all the old ones they come across are perished. Waiting on a response from Mazdabongo.com
Post by g8dhe » Mon Oct 05, 2020 3:37 pm
Also Vospers get lots of recomendations again part not listed by they do invite you to call them!
The part number is S10H28012 "Sheet, Rubber" http://www.lushprojects.com/bongopartsm ... f02.html#2
https://parts.vospers.com/
willow2u
Post by willow2u » Mon Oct 05, 2020 4:05 pm
if you type rear spring mount on ebay there must be a similar mount out there
willow2u
Post by willow2u » Fri Feb 26, 2021 3:37 pm
did you sort out this part you wanted
Alkers
Post by Alkers » Tue Mar 02, 2021 5:55 pm
I did in the end - I got two from a breakers in the UK but they were only marginally better than the ones I had already so I suspect to need to replace them in the near future.
https://www.spaccer.com/ Will make a custom mount but involves raising the van slightly at least. These are pricey too.
I've actually sourced a perfect fit shock mount from a russian vehicle, which I bought on ebay through an instagram contact - I've just asked him now if he's any more to sell and will post the link if he does. These are a perfect fit but also raise the ride height slightly. These cost me about 45e including shipping for a pair. I've not installed them yet but I have a spare set of springs to measure against an they're perfect.
willow2u
Post by willow2u » Tue Mar 02, 2021 8:02 pm
What Russian vehicle was it
rita
Post by rita » Wed Mar 03, 2021 1:04 pm
Alkers wrote: Mon Oct 05, 2020 9:38 am Does anyone know where to source the rubber part that goes between the rear coil spring and the cup on the suspension mount? Getting a small bit of rust addressed and these rubbers are badly perished.
try here http://www.autospares.eu/price-lists/mazda/3526/
Alkers
Post by Alkers » Wed Mar 03, 2021 4:49 pm
rita wrote: Wed Mar 03, 2021 1:04 pm
They don't have it. There are loads of these type of sites, where they list all available part numbers and allow you to place an order. Once you do, they try to source the part and come back saying it's not available.
Alkers
Post by Alkers » Wed Mar 03, 2021 4:52 pm
Alkers wrote: Tue Mar 02, 2021 5:55 pm I did in the end - I got two from a breakers in the UK but they were only marginally better than the ones I had already so I suspect to need to replace them in the near future.
Here is the ebay link - I can confirm these fit perfectly. Shipping was slow enough though!
https://www.ebay.com/itm/233917695147
willow2u
Post by willow2u » Wed Mar 03, 2021 9:26 pm
Having some made atm from mdpe for £75 it seems that the Kia sorento rear spring pads would be a perfect fit without the extra lift part no 55131-3E000
Alkers
Post by Alkers » Fri Mar 05, 2021 1:47 pm
Did you try them for size? I ordered a load of various ones - they're typically only a couple of euros each but none were an exact fit. I can't recall if one was from a sorento, definitely a few santa fe etc.
willow2u
Post by willow2u » Sat Mar 06, 2021 12:01 am
was going to but having them made up so didnt pursue any further
willow2u
Post by willow2u » Sat Mar 06, 2021 7:45 pm
Picked them up today and now axle is back in just a million other things to sort now
