The Rust Directory
Re: The Rust Directory
Post by Bob » Sun Feb 07, 2021 10:43 pm
Thanks for update and pics. 👍
Post by mikeonb4c » Mon Feb 08, 2021 7:42 pm
Good looking job and all done when you couldn't have been out using it due to Covid19 but now looks like it'll be ready for when lockdown eases and the summer starts. Result!
Can't remember what model it is and what you've done but make sure any metal pipes like the ones to rear heater and autobox<->cooler are sorted as well as they go at a similar age to the bodywork. Also the main radiator is probably due to start leaking at around 20yrs of age. Don't want ot get the bodywork all sorted then have mechanical issues on 1st outing :shock: #-o
willow2u
Post by willow2u » Mon Feb 08, 2021 9:47 pm
Done away with rear heater anyway can’t see the point for it I’m turning the new void into a storage area 👍 will be re doing auto pipes just got to check if pressure is the same and it’s a new rad 😎
willow2u
Post by willow2u » Sat Mar 13, 2021 9:26 pm
Finished article
willow2u
Post by willow2u » Sat Mar 13, 2021 9:28 pm
No rear heater or troublesome extra pipe work just extra storage once I’ve lined it out
Post by mikeonb4c » Sun Mar 14, 2021 7:05 pm
willow2u wrote: Sat Mar 13, 2021 9:28 pm No rear heater or troublesome extra pipe work just extra storage once I’ve lined it out
Not a bad plan. Interesting thought occurs that the space vacated by the rear heater unit might even house a diesel heater, maybe even retaining the ducting and outlet controls? Or would they not be up to the heat from a diesel heater :roll:
willow2u
Post by willow2u » Mon Mar 15, 2021 6:45 pm
I think I did read somewhere someone did put a diesel heater in there
willow2u
Post by willow2u » Sat Mar 20, 2021 6:44 pm
Started stripping off the side skirts of the donor bongo it’s a bit of a warning for people buying bongos with these on outwardly it looked like it would need new arches but once they were off you could see the carnage you obviously can’t take them of to look if you’re buying one but I think a rule of thumb would be if it needs wheel arch repair it’s almost a certainty it will need sill work
willow2u
Post by willow2u » Sat Mar 20, 2021 8:01 pm
Also while reassembling the van I noticed how useless the plastic shield os rear covering filler tube really is all the dirt gets propelled over the top of the cover and gets lodged behind it then keeps all the wet there everytime it rains totally useless would probably be better of without it so am going to modify the spare one I have to close of the entry point at the top
JuicyJoy
Post by JuicyJoy » Tue May 03, 2022 9:21 pm
sleepwalker wrote: Wed May 06, 2015 10:47 am I'd like to recommend the Bongo Body shop in Barnsley. Dave is a bongo fan himself and fixed up and resprayed a few nasty rust patches for me. He also removed all the old cracked decals and sprayed the sides of the aft where the decals were removed. After a machine polish I have a great looking van. You can find the contact details for the Bongo Body shop in the classified section of this site. He was also fixing up some very rotten arches for another customer when I collected my van. Would definitely recommend.
I'm Sheffield-based. Anyone used "Dave" recently? Still recommended or better alternatives? I've got smalll, surface-level rust patches at the corners of the wheel arches that I'd like looking at before the rot spreads! TVM in advance.
Post by Ian » Thu May 05, 2022 8:15 am
Dave is very busy and you have to book weeks in advance. Have you tried this firm on Abbeydale Road? They have been recommended.
John Bee Sheffield 0114-249-4883 https://www.carrepairsheffield.co.uk/
kloonsy
Post by kloonsy » Thu Oct 27, 2022 9:08 am
Ian wrote: Thu May 05, 2022 8:15 am Dave is very busy and you have to book weeks in advance.
Thanks Ian. Just to let people know, I've recently taken on a very experienced Bodyman/painter to increase capacity but still keep the high standards. Nothing I hate more than having people waiting. 🚐
The Bongo Bodyshop - For all your Bongo Bodywork needs.
07584 134811
Advice is free.
Post by Ian » Thu Oct 27, 2022 12:50 pm
Cheers Dave. I'll put a notice out on the main website and here on the Forum.
LordBongoOfBanbury
Post by LordBongoOfBanbury » Fri Jul 28, 2023 10:41 pm
Hello all,
New here, please be kind!
Although I've been a long time Bongo admirer, I only yesterday joined the ownership club, picking up a nice 2002 2.5l V6 example from Winchester.
Inevitably, it has some rust issues despite being undersealed by JAL when it was imported in 2011.
The most recent MOT (October 2022) gave an advisory of rust on the offside front section of the chassis (pictured). Does anyone have any experience with this particular corrosion issue, have any suggestions as to the repair costs and where the best place near to Banbury is to take it to have the work done?
Cheers! Matt. Image
Post by Ian » Sat Jul 29, 2023 7:57 am
We don't have any Bongo specific rust experts in your area I'm afraid. But you could always try the national Rustmaster chain (who are very good) or contact a local car restoration society as they will do this kind of stuff all the time.
