Starting problems
steve9617
Starting problems
Post by steve9617 » Mon Feb 01, 2021 12:23 pm
Hi all
I have an unusual problem (I think).
My 95 2.5 diesel struggles to start once the tank gets below about 2 thirds full.
While it will eventually start but just turns over until I catches and springs to life.
The accelerator pedal is also pretty non responsive for 10 secs and then the engine will rev normally.
Im not sure if this is a battery issue or a fueling issue.
Any advice is greatly appreciated.
Steve
Re: Starting problems
Post by Bob » Mon Feb 01, 2021 12:29 pm
Try loosening the fuel cap and see if you get a 'whoosh' of air.
Possibly the breather blocked?
steve9617
Post by steve9617 » Mon Feb 01, 2021 1:24 pm
Bob wrote: Mon Feb 01, 2021 12:29 pm Try loosening the fuel cap and see if you get a 'whoosh' of air.
Thanks Bob I'll check that out later.
If I get the 'whoosh' is there a good way to unblock it or just stick something long down there and see what happens?
Steve
Post by Bob » Mon Feb 01, 2021 1:45 pm
I'm pretty sure Geoff has put up some pics on how to dismantle, and then clean, the filler cap. :)
Post by g8dhe » Mon Feb 01, 2021 1:59 pm
The valve in the cap is just clipped in, there are a couple of variations can't remember if that was the diesel or petrol version but they are similar.
steve9617
Post by steve9617 » Mon Feb 01, 2021 2:52 pm
Thanks guys it's much appreciated.
I'll see what happens.
steve9617
Post by steve9617 » Mon Feb 01, 2021 6:59 pm
Sadly no 'whoosh'.
It still stuttered with the cap off.
Thanks for the advice but any other guesses?
Post by Bob » Mon Feb 01, 2021 7:16 pm
Ahh well, at least you've eliminated that.
willow2u
Post by willow2u » Mon Feb 01, 2021 8:41 pm
It must suck a bit of air somehow
Post by Ian » Tue Feb 02, 2021 9:45 am
Perished seals on the diesel pump would introduce air in to the fuel line.
Post by Northern Bongolow » Tue Feb 02, 2021 9:18 pm
As above with the pump, try parking it nose downhill see if it improves things.
