Door locks
Weavy
Door locks
Post by Weavy » Fri Dec 04, 2020 12:01 am
Hi guys just wondering as I can't see the answer via google what is the difference between the locks as ones for air bag and none air bag I assume that's its more to do with the ignition
Re: Door locks
Post by g8dhe » Fri Dec 04, 2020 9:41 am
Not quite sure what your getting at up to 2000 there isn't any connection between the door locks and the air bags.
nth
Re: Door locks
Post by nth » Sat Dec 05, 2020 7:08 pm
The steering locks are (apparently) different between airbag & non airbag models.
There wont be any difference in the door locks barrels.
On that note has anyone found a supplier of blank locks so I can make it up to suit my key? Some scumbag (unsuccessfully) tried to break in to mines last week the lock face is damaged. I have OCD about having different keys/locks so not putting a different barrel & key in.
95 2.5d 4WD AFT
Weavy
Re: Door locks
Post by Weavy » Sun Dec 06, 2020 8:28 pm
Thank you guys I did mean the barrel and not door locks but all good as I've just sold a set but doesn't need the ignition. While we're on about locks seeing a few ppl have had there's done over is there a Anti tamper one that fit know the ones that take a round key
nth
Re: Door locks
Post by nth » Mon Dec 14, 2020 9:03 pm
The tubular locks are a waste of time, there are tools available online that can open them with practically no skill whatsoever.
The other issue is you could get the best hardened, drill & pick resistant locks but at the end of the day they are mounted on a piece of sheet metal a few mm thick. They just puncture the metal around the lock with the screwdriver & pop it out of the door.
95 2.5d 4WD AFT
