Banjo Filter
Tombo
Banjo Filter
Post by Tombo » Mon Nov 30, 2020 9:43 pm
I went to clean the banjo filter on my 2000 drive by wire diesel, there isn't one in there. I was helpfully directed to some fuel pump diagrams and it seems like the drive by wire pump doesn't have a filter but the pre 2000 diesels did.
Can anyone confirm this and why they would not continue fitting them? Maybe another filter somewhere else?
Anyway, it might be worth updating the factsheet on this - I've got one coming in the post 😂
2000, 2.5 Diesel, 4wd, AFT
Re: Banjo Filter
Post by g8dhe » Mon Nov 30, 2020 10:34 pm
Is the Banjo joint still there but no filter fitted ? Its quite common for people to damage them in getting them out!
Tombo
Re: Banjo Filter
Post by Tombo » Mon Nov 30, 2020 11:14 pm
Thanks, that's what I had read but have a look at these diagrams. Maybe the diagrams aren't conclusive though. Here's the pump including the filter:
And here's the drive by wire pump:
However I've also just seen the earlier pump diagram and that doesn't show the filter either so I'm confused. Maybe I'll put one in after all.
https://lushprojects.com/bongopartsmk2/ ... o=.html#16
rita
Re: Banjo Filter
Post by rita » Tue Dec 01, 2020 12:24 pm
On the later model Bongo they do not have a filter/strainer on the IP.
Tombo
Re: Banjo Filter
Post by Tombo » Tue Dec 01, 2020 3:29 pm
Thanks Rita, I'll leave it as it is then. How did you find that out?
Hazy
Re: Banjo Filter
Post by Hazy » Sun Dec 06, 2020 11:12 am
Hi all,
New to Bongos. Just planning to change my fuel filter on my 1999 facelift 2.5td Bongo. I have also got a new Banjo filter and spring.
Not 100% sure where this is located on my van.
Has anyone got photos they can post of the bolt I need to in screw please?
Many Thanks
Re: Banjo Filter
Post by g8dhe » Sun Dec 06, 2020 12:09 pm
Here you go;
Re: Banjo Filter
Post by Ian » Wed Jan 13, 2021 2:44 pm
I've just tried to order some more Banjo filters and springs from our supplier but have been told the manufacturers have given a date of 4 to 6 months for delivery and will only re-manufacture if I order 200 of them. We currently have 1 filter and 4 springs left.
I have the Bosch and Zexel part numbers for these components. But does anyone have the Mazda part number? I can't seem to find it on Lush.
rita
Re: Banjo Filter
Post by rita » Fri Jan 15, 2021 12:18 pm
Try WL0113VF5
Re: Banjo Filter
Post by Ian » Fri Jan 15, 2021 1:29 pm
Cheers Rita, have now tracked some down.
