turfite9999
- Bongonaut
Post
by turfite9999 » Sun Jan 12, 2020 8:15 pm
Hi guys happy new year
Does anyone know of a way to test my low coolant alarm to see if it works, many thanks in advance
turfite9999
Post
by Bob » Sun Jan 12, 2020 9:47 pm
Depends which one you have.
Best ones self test, otherwise do you have the instructions?
haydn callow
Post
by haydn callow » Mon Jan 13, 2020 10:52 am
If it’s one of ours (Haydn Alarms) then a small red led should flash and a beep should be heard when you switch on the ignition. That proves the alarm is working and your coolant level is good. To SUPER prove it’s working siphon coolant out of the tank until the level drops below the sensor screw (use the wife’s chicken baster). You need ignition on to do this.
turfite9999
- Bongonaut
Post
by turfite9999 » Mon Jan 13, 2020 5:55 pm
thank you for that guys
jaxonedy
- Apprentice Bongonaut
Post
by jaxonedy » Tue Nov 10, 2020 8:41 pm
Hi all. I was checking my Haydn alarm and touched the relay/alarm under the steering wheel and and a cylindrical piece of plastic came away from the relay - my fault as pulled it out from against the lower dash when jammed. Now no alarm. Is the part replaceable at all. 1st bongo so apologies for the lack of knowledge. Incidentally I should have cleaned the screw as per thread instead of attacking the source of the noise. Lesson learned.
Post
by Ian » Tue Nov 10, 2020 9:21 pm
Try contacting Jo at
www.coolantalarm.co.uk. If you are in luck she may have some bits from customer returns on a shelf somewehere.
haydn callow
Post
by haydn callow » Tue Nov 10, 2020 10:21 pm
Hi, are you sure it’s a Haydn alarm ? Assuming it is and the bit you pulled away is a small black cylinder about 1 inch diameter and 1.5 inch long then it is a very old one...all I can suggest is you strip the alarm out and send it to us for repair FOC....if it’s irreparable we can do a deal on a new replacement.....whatever the outcome I suggest you get a working one ASAP.
jaxonedy
Post
by jaxonedy » Sun Nov 29, 2020 9:30 pm
Hi Much appreciated. The Bongo is off road for the season but will retrieve the old relay and contact via your web site.
