Over heating
Big E
Post by Big E » Wed Feb 21, 2007 9:19 pm
Would a faulty thermostat cause my problem?
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:20 pm
it can cause overheating, but the water loss is puzzling
Image Pete
Big E
Post by Big E » Wed Feb 21, 2007 9:22 pm
Its not loosing water at present, it is just constantly bubbling and throwing it out the tank
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:25 pm
Thats what mine did, are you getting white exhaust fumes, mine ran clear, coolant system overpressurised because of crap coolant and dodgy thermostat and airlock
Image Pete
Big E
Post by Big E » Wed Feb 21, 2007 9:26 pm
I am not getting white smoke
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:28 pm
now that is a good sign, when head went on our original engine, it looked like a steam train :cry: Is the engine oil emulsified?
Image Pete
Big E
Post by Big E » Wed Feb 21, 2007 9:29 pm
The oil looks fine, when I last looked
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:31 pm
Then I doubt that head or gasket have gone, check thermostat, radiator and expansion bottle caps, make sure they bleed the system
Image Pete
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:32 pm
bumbly what do you think
Image Pete
Big E
Post by Big E » Wed Feb 21, 2007 9:33 pm
I just hope the problem is solved soon. It would be nice to use the Bongo
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:38 pm
mine was off the road almost 2 months, but in the end I changed the thermostat, replaced any dodgy hoses and clips, changed rad cap, changed expansion bottle cap, flushed the system, flushed it againand again, then filled with good quality coolant and bled the system, at that time I had not seen manual and just bled it by instinct. It has done several thousand miles now, up some big hills and the temp stays constant. Hope this does not sound bigheaded, it is not meant to :oops:
Image Pete
Big E
Post by Big E » Wed Feb 21, 2007 9:41 pm
I will pass on your advice to my Garage. Cheers
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:44 pm
good luck please keep us posted on progress :wink:
Image Pete
Big E
Post by Big E » Wed Feb 21, 2007 9:45 pm
Any Bongo experts want to come and have a look at it :o
Peg leg Pete
Post by Peg leg Pete » Wed Feb 21, 2007 9:48 pm
wish I could, I have a trip to Bedlington to do at some point, but not sure of time scale :roll: If you persivere you will have your Bongo back on the road, keep positive
Image Pete
