Electric windows
callaway
Electric windows
Post by callaway » Wed Feb 21, 2007 7:39 pm
I have a problem with electric windows. My driver window electic window will not work and also will not operate the passenger side (although the passenger side operates from it's own switch. Does the drivers side switch box have it's own fuse and if so how do I identify it in the fuse box? Any other ideas much appreciated.
John from Devon
Post by francophile1947 » Wed Feb 21, 2007 8:11 pm
A broken wire, between the door and body, is a frequent problem with the windows.
dandywarhol
Post by dandywarhol » Wed Feb 21, 2007 8:37 pm
So is a dry solder joint in the circuit board in the driver's switch.............
David Edwards
Post by David Edwards » Thu Feb 22, 2007 1:06 am
If you are going to check the wires from the car thru the door pillar, be careful, when you have removed the corrugated cover there are loads of very thin wires each of which have to be examined very carefully as a break may not be obvious, as I found when my central locking stopped working, There is not a lot of play in the wires either and they are bloody awkward to get at too. Good luck and hope it sorts soon. Happy motoring.
cezeta
Post by cezeta » Sat Feb 24, 2007 12:50 pm
i have the same problem, i bought a new switch and its the same so must be the the door loop.
the electric mirror has stopped working too.
is the loop part of the loom or can that section be replaced?
cezeta
Post by cezeta » Sat Feb 24, 2007 6:10 pm
i just stripped the hinge loop to find 3 wires broken. i will solder them up tomorrow so an easy fix :wink:
