Emissions Diagnostics on V6
Post by Ian » Mon Jul 20, 2020 8:50 pm
Here's a query received at Bongo Towers. Can anybody help?
Problems with MOT emissions on on V6 2.5, 2002 reg, very high. Mechanic says it's injector 3 or the components to it but he hasn't got the tackle to diagnose it. Hope you can advise me on this issue, it would be much appreciated. Thanks, Gray.
Bongolia
Re: Emissions Diagnostics on V6
Post by Bongolia » Tue Jul 21, 2020 8:55 am
Hi Ian
He should have been given a print out of the gas readings . It would help if we could see those.
Post by Ian » Tue Jul 21, 2020 11:08 am
Bongolia wrote: Tue Jul 21, 2020 8:55 am Hi Ian
I've sent the link to this discussion to him.
gashmore60
Post by gashmore60 » Tue Jul 21, 2020 2:00 pm
MOT Failure (major defects)
exhaust lambda reading after 2nd fast idle outside specified limits [8.2.1.2 (c),
Same for the exhaust carbon monoxide content at idle and 2nd fast idle [8.2.1.2(b) ,
says its coming from around injector 3 ,says it needs someone who can get to and diagnose the problem.
Any help would be very helpful , Thanks Gray.
Post by g8dhe » Tue Jul 21, 2020 2:49 pm
I've seen reference to this on FB a couple of times and a couple of MoT Testers have confirmed this interpretation, however if this is a 2002 vehicle it needs to have been manufactured before 1 st Sep 2002!
rita
Post by rita » Tue Jul 21, 2020 5:20 pm
gashmore60 wrote: Tue Jul 21, 2020 2:00 pm MOT Failure (major defects)
This might sound like a silly question, did it fail the MOT test .
Bongolia
Post by Bongolia » Tue Jul 21, 2020 6:11 pm
Its the emisions print out needed not the fail criteria. The gas readings will give a good clue as to whats going wrong.
gashmore60
Post by gashmore60 » Wed Jul 22, 2020 5:34 pm
All the CO tests failed . Natural 2nd Idle test engine speed 450-1 500 rpm not checked
CO limit =<0.50%
actual value 1.69% Fail
Took it to Contract Mechanics bongo in Harbury , also said its only firing on 5 ,oil in cylinder need rockerfella gasget.
After hed cleaned it up said its fine now but within a day will leak into the plugs again ,says it would pass emissions test now,
drove it back too Coventry about 40 min, had it checked and was told still firing on 5 same problem .
Any help much appreciated .
