I'm looking for guidance on course of action regarding the two attached photos.
Leak3 is a close up and leak4 shows two fine jets of coolant.
Is this the oil cooler, and is this fixable? If so what parts etc do I need?
https://www.dropbox.com/sh/ysmshzvmn65a ... qGewa?dl=0
Hope the link works, can't seem to add photos
Coolant leak 1996 2.5TD
Re: Coolant leak 1996 2.5TD
The thin hose going from right to left with the silver heat shield on it is a turbo coolant hose, check the pipe and clips carefully.
