V6 Cam belt and oil seals change
Eratosthenes
I suspect the crank oil seal needs replacing. I have used a "seal conditioner/additive" to get through the lockdown period. As things are starting to get moving again, I need to get it sorted. I know it isn't a cheap if a full job is done with water pump and tensioner etc. Can anyone give me a ballpark figure of cost and how long it may take.
Re: V6 Cam belt and oil seals change
In the order of £700 in 2013 and last time in 2018 it was £800, both times a few other bits as well plus this is down on the South Coast so hourly rates may vary!
Eratosthenes
Geoff, thanks for that, at least I have an idea now. Would that be over a couple of days?
Yes I think its about a days work in all as it takes a little while to get the front of the engine fully accessible, I normally drop it in and they drop it back to me when done, there on old school garage, look after a lot of the local taxi fleet and driver training guys so they do sometimes have rush job on I just let them know if I'll be away at the end of the week or not!
Lot to be said for an Old School garage.
Eratosthenes
Geoff thanks for the reply. Hopefully I can arrange with the garage to collect and drop off, they do a lot of work with Bongo's but unfortunately about 15 miles away. Normally I drop it off and wait/shop.
