I've had a knocking noise when lifting off the throttle coming from the middle of the bus . I had a mechanic quickly look at it ( he will look at it again in the new year ) and give it a drive , he thinks it could be the transfer box giving up as she also crunches as you turn tightly left or right , like a bad cv joint , the props all look good with no play or excessive movement .
My question is really a research one for now, but can the transfer box be rebuilt or replaced ?
Also would making a 2wd bus out if it be an option and remove the box completely or all the bits inside ?
I've done nothing like this before so as you can tell I know very little about it
If anyone has a known good box out there that they ar willing to sell you might have a customer ! Please get in touch .
I will of course talk to Emma in bongo spares if this is the problem .
As always any and all help and advice greatly appreciated
Brian
