2L petrol engine
nickhobson25
2L petrol engine
Post by nickhobson25 » Sun Oct 13, 2019 8:31 pm
hi
So travelled 40 miles today without a problem.
Stopped to pick something up then when I started up again the "check engine" light came up.
Drove to a nearby supermarket for a coffee. Came back and no light (scratched head).
Travelled home the 40 miles all good. Stopped then turned the ignition and the light came back on!
Any clues?
Re: 2L petrol engine
Post by g8dhe » Sun Oct 13, 2019 8:51 pm
Which engine ? If its the 2l then it may well be an overheated catalytic converter possibly affected by passing thru water splash in the current weather.
nickhobson25
Post by nickhobson25 » Sun Oct 13, 2019 9:19 pm
2L petrol.
Was damp today but not raining. Getting a diagnostic fault reader so it might shed a clue.
nickhobson25
Post by nickhobson25 » Sun Oct 13, 2019 9:21 pm
Lambda sensor maybe?
Had a service and MOT only two weeks ago.
:roll:
nickhobson25
Post by nickhobson25 » Mon Oct 14, 2019 4:57 pm
so got an OBD II scanner, plugged it in but nothing.....grrrr!
Looks like its fitted but not connected? There is another older diagnostic port under the glovebox. different PIN layout . can you get a reader for that or would a garage have one?
Post by g8dhe » Mon Oct 14, 2019 5:26 pm
There is no need for a reader just a link and lamp an eyeball and a brain http://www.philmcfadden.co.uk/MazdaDiagnosticBox.htm
TheLongRoad
Post by TheLongRoad » Fri Dec 06, 2019 7:32 pm
Bit of a thread revival here: So I’ve had a similar experience in past. The diagnostic tool needs the engine running to give he fault code. Most likely an O2 sensor. If it’s that then a Bosch universal part can be spliced into the Bongy. Costs about £30 ish for part :D
2002 Friendee 2.0 ltr Petrol.
