Rev Counter slow to start
Eratosthenes
I have a V6 year 2000 tin top.
For the last few journeys/days my rev counter hasn't worked for the first few miles, then when it does decide to, it acts normally.
If I am parked for a short time then it works on start up, but doesn't if parked for a few hours.
Everything else appears to be fine and functioning well.
Any ideas or suggestions would be appreciated.
(We are in the middle of a camping trip in mid Wales at the moment).
Re: Rev Counter slow to start
Low battery, or alternator failing could be worth checking .
Eratosthenes
Battery voltage engine not running 12.56 v engine running 14.55v showing at main battery and leisure battery. Went on a short trip earlier and Rev counter worked right away there and back.
At initial switch on does your Charge light come on? Then when the engine is running does it go off ?
Eratosthenes
It does Geoff - go out when engine starts.
Well that does indicate that the Charge circuit is working and the Alternator thinks that it is charging, could still be a dead battery not holding charge or a problem with one of its connections.
Eratosthenes
Thanks Geoff and Northern Bongolow for replying.
This morning first thing I had a prod and poke around the battery terminals and connections. Later today we did about 160 miles with some stops and the rev counter behaved as it should.
After doing some searching google about battery information I realised my main battery has a magic eye and some information in Japanese. It isn't showing green as per the diagram, but black. I guess that this indicates the battery is approaching the end of its life? It is a sealed battery and I cannot check or add distilled water. When I return home it the battery will be replaced with a Bosch. I will be cleaning all the connections at the same time. However I do have a question with regards to doing this and would appreciate advice on the following. There is an immobiliser fitted but the fob has seen better days so I avoid using it. I know that when I change the battery it will set the alarm off when I turn the ignition on. I have looked in to having the immobiliser removed which I think is now a priority. Is it ok to keep the system energised by taking parallel connections from the leisure battery, ensuring they don't make contact with anything. I dont understand exactly how the split charging loom works and I am not sure if this would be detrimental to this. So any advice would be appreciated.
The green "eye" shows the state of charge, if its staying in Black then that suggests either not being charged or a dead battery, most garages can test the battery itself with either a modern tester or a "drop" tester to see how much charge is being retained. However if its an original Jap battery then the chances are its well beyond its life having been left to go flat during its journey over here!
Eratosthenes
I have owned the Bongo since imported and that is just over 4 years so I guess the battery has just about had it. I will go to a garage /battery supplier and do as you say Geoff and get it checked under load to confirm.
Eratosthenes
I changed the battery a couple of weeks ago and the rev counter behaved perfectly and I thought that was the culprit. However today the rev counter has decided not to work again.
I will check the voltages at the battery with the engine running and with various loads (A/C Headlights etc).
Has anyone any other suggestions. I have looked at various loom connectors for making good fit and being clean.
Thanks in anticipation.
Could be an intermittent sensor, not heard of many problems on the V6 however, but can't be rules out without checking its 18-230 on this diagram http://www.lushprojects.com/bongopartsm ... no=.html#2
Eratosthenes
Geoff thanks for the information. I know it may be basic to some but I am having trouble actually locating the sensor. I have searched the forum and although there is a photo I cannot make out where it actually is? Any pointers appreciated.
Yup here is the position, bit of a sod to reach I think. If you have a meter its should show a resistance of 110-150 Ohms.
Eratosthenes
Geoff - that's perfect - many thanks.
Yes, well done Geoff for removing the engine from your Bongo just to take a photo of the sensor. Hope it doesn't take too long to re-assemble it....
