HI All,
Have just been informed from the garage that I need to replace the Aux belt tensioner and ac belt tensioner as the bearings are worn and making some noise, I can't find the part in the bongo land shop and am a bit unsure whether the bearing can be replaced or I need whole parts? Any advice and where I can buy the parts would be great.
Dan
Parts Required - tensioners
Dan,
99 V6!
99 V6!
Re: Parts Required - tensioners
Hi Dan, bearings are widely available, you just need the number of the bearing or the physical size. Your mechanic should be able to source the parts required.
Take care.
Take care.
Thanks for the reply tennmal, after a bit more digging I have sourced new parts ready for our first trip this weekend.
Dan,
99 V6!
99 V6!
