restarting after 18 months SORN?
Hello all
Our bongo has been SORN for 18 months, sitting untouched. (Yeah, bad. I know).
I want to see if I can get her back to life. Any suggestions/recommendations? So far:
1. Battery has been disconnected whilst she's been hibernating. Now fully charged & re-connected
2. Checked oil & water
3. Turned the engine over. It's turning fine, and coughed into life briefly. However, now just turning over but no sign of firing. Possibly lack of fuel reaching injectors?
Do I need to drain diesel from tank / should I? If so, are there instructions anywhere for doing that? Presumably I'll need to prime the diesel pump again afterwards?
Thanks.
Thanks.
Re: restarting after 18 months SORN?
Have a Google for 'Diesel Bug'.
That might be the problem after 18 months.
Oh. Dear.Have a Google for 'Diesel Bug'.
So: at the very least, full drain of tank + clean of fuel lines?
Probably best to change the fuel filter (cannister) and also check the state of the "banjo" filter either could be causing the problem and would need to be changed if you do have "diesel bug"!
The banjo filter is shown below;
Thanks Geoff.Probably best to change the fuel filter (cannister) and also check the state of the "banjo" filter either could be causing the problem and would need to be changed if you do have "diesel bug"!
Are there instructions anywhere for the whole procedure? i.e. draining tank, cleaning lines, replacing filter, ...
I see there's both a service manual and WLT engine manual in the shop. Would either of those cover it?
Thanks.
Not really, changing the filters yes just do some searched on here - just make sure your reading up on the right engine of course a V6 petrol and a 2.5l diesel are a bit different
Hi - How long were you turning the engine over for? If the seals on your fuel pump are past their best the diesel can drain back out of the engine past the seals and back into the fuel tank. We didn't use our Bongo for 3 months or so last year and when we came to start it displayed the same symptoms as you. A good couple of minutes turning the engine over solved this as it gave the fuel pump time to get the fuel back into the engine and it started up. Its been fine since. your battery needs to be in good shape to do this though.
My wife's Mazda 2 has also done the same after only a week or so without use, so it seems to be a Mazda issue....apparently if its parked on a hill it can make this more likely.
sfinnie , some fuel filter housing have a hand primer, worth having a look, if no joy you could remove the injector pump supply line and prime the IP.
Take care.
Take care.
I know it's been a few years, but I am wondering how you got on with this?sfinnie wrote: Sun Feb 24, 2019 1:41 pm Hello all
Thanks.
I am resurrecting my Bongo after being laid up for many years too. I have got it started but it won't rev past around 1800 rpm, so I'm wondering if this diesel bug thing is the issue?
Did you discover this bug? And did you resolve your problem? I am interested to know.
1800 revs is about when the turbo kicks in, take a good look round the small pipes and actuator that controls it's operation, also check the air filter housing and pipework as this makes a great winter nest for mice.
Ok, what is it that I'm looking for?Northern Bongolow wrote: Sun Jun 27, 2021 10:37 pm ... take a good look round the small pipes and actuator that controls it's operation,
Do you mean inside the air filter housing?... also check the air filter housing and pipework as this makes a great winter nest for mice.
Thanks for your prompt response and advice which is greatly appreciated.
Yes, inside the pipework and filter housing
