Petrol 2.0 2005 - Ignition switch diagnostics with video
ognob
Post by ognob » Tue Feb 19, 2019 6:58 pm
New to me bongo, purchased with a few known problems.
Currently I have a cutting out issue, don’t think it’s related to the faulty ignition switch, but having a faulty switch can make restarting when I’m in the middle of a j7nction a bit more exciting, so it’s a good thing to fix as it does need doing
Some days it’s fine, other days it can be 30 seconds of key in and out, back and forth until we get lights on the dash allowing us to crank
Please watch this YouTube video I took
https://youtu.be/CBujOdiW-q0
The actual mechanical barrel is fine
Am I right in thinking the bit of beige plastic at the end which I point to that contains the electrics which is simply turned by the barrel.
Can I just remove that beige bit and have a go at cleaning it up
The inside of this bongo is (was) pretty disgusting, lots of dust grime muck fluff hair everywhere
I’m hoping I can just replace the electrical bit without having to do the barrel
Any thoughts?
Your help and time is appreciated, this is our car which we use for a young family so I’m not really using it as it’s a bit of a gamble.
ognob
Re: Petrol 2.0 2005 - Ignition switch diagnostics with video
Post by ognob » Wed Feb 20, 2019 2:15 pm
Ok I removed the switch at lunch and cleaned it up
Was packed with grease on the terminals inside ? Is this the norm
So far so good, but it could be fine for a few days then play up.
Will update in a few days
Post by g8dhe » Wed Feb 20, 2019 2:41 pm
Its not a problem provided the grease is the right type!
Needs to be a type that doesn't melt with small temperature increase, nor "burn" - i.e produce a carbon deposit with arcing between contacts.
It can help to ensure that dust and dirt doesn't reach the contacts causing problems, but can also hide and trap dirt if its been added after manufacture.
ognob
Post by ognob » Thu Feb 21, 2019 1:23 pm
Another day on, seems ok still
For future reference if you come across this thread with a similar problem, it looks like Mazda 323 has the same ingition switch
Maybe some mx5 as well
Thankyou
ognob
Post by ognob » Tue Feb 26, 2019 8:49 pm
Still
Good nearly a week later, pleased
