my coolant is making me go bongo!
Re: my coolant is making me go bongo!
Post by mikeonb4c » Mon Aug 06, 2018 10:15 am
Bob wrote: Sun Aug 05, 2018 6:00 pm And safety glasses. :wink:
Worth refering to 'Little Johny Head in a Bongo'. :lol:
Not to mention that other miscreant - Shock Heater
https://en.m.wikipedia.org/wiki/Struwwelpeter
Woops i just did! :lol: :lol: :lol:
fordmill
Post by fordmill » Thu Dec 27, 2018 5:05 pm
Hi Ada, Where did you get the funnel from as I am having the same issue?
Post by Bob » Thu Dec 27, 2018 6:16 pm
What you need is a funnel with a smooth outside to the spout bit.
Lots have ribs on to allow air to exit when filling, say, a bottle.
What you want is a tight fit in the tube. :wink:
https://m.youtube.com/watch?v=WScEJKNMdgI
The blonde one was married to Pete Waterman.
Post by Northern Bongolow » Fri Dec 28, 2018 8:16 pm
The dark haired one was me.
I always wanted to be a backing singer, flicking my bits about. The old male soul groups were the best.
Post by Bob » Fri Dec 28, 2018 9:31 pm
The one on the drums or the dancer? 8)
teenmal
Post by teenmal » Fri Dec 28, 2018 11:21 pm
LawrenceStanley wrote: Fri Aug 03, 2018 6:40 pm Hi Guys,
I recently purchased a 1996 bongo, it's old but its a lovely vehicle. I've just completed a 2300km trip to and around Scotland from Cornwall and I have had some strange coolant issues I am hoping someone might be able to help with. fyi it has a low coolant alarm.
So firstly, the bongo looses coolant. I know that because on cold days after the engine hasn't run for a few hours the coolant level drops in the expansion tank and the alarm starts. This is the first thing i don't understand. Why not on a hot day during use?!
Anyway, due to being in remote places I have had to top up with regular water quite often. on one short (3mile) drive we parked up for a cuppa and i noticed loads of coolant dripping out of the bottom left corner of the radiator. checked all over and couldnt see a leak. Assumed it was from behind a fan but it definitely was not the coolant tank. topped up with water, drove around for at least 50 miles and no leak after...
On our 12 hour drive back to Cornwall, around Manchester, we encountered the inevitable traffic jam, after a while of stop starts i saw steam coming from the front bonnet! oh no, engine is cooked i thought, but luckily it was at that moment we started moving again. drove to next services (5 miles ish) and there was evidence of water spraying out, but no leak visible and topped up coolant tanks and all way good. by rights the engine should have been toast! but still cruising along happily...
Drove all the way back and the last 5 miles the temperature gauge started fluctuating, going from 11 o'clock to cold and back... and still no visible leak. radiator is still full. expansion tank not so much...
Does anyone know what on earth is going on?
As a matter of interest did your coolant alarm warn you that the coolant was Low.
Post by mikeonb4c » Sat Dec 29, 2018 12:55 am
So it looks like the LCA has at some point done its job. Later on the OP writes about steam from header tank, suggesting coolant could be boiling. I think this is a situation where a low coolant alarm may not detect level drop (maybe since boiling coolant is causing wetness throughout the header tank, masking the true situation?). Mind you, it seems to me its hardly needed by then as the 'steam alarm' has kicked in.
All this happened back in August so I'd hope by now the OP has managed to get the problem sorted.
fordmill
Post by fordmill » Fri Feb 22, 2019 5:33 pm
I had a similar issue, I found that the radiator cap was tired and was letting water drain from the leak off when parked up after use. Might be worth a cheap try?
