Bongo not starting
Gertie
Bongo not starting
Post by Gertie » Sun Jun 10, 2018 3:47 pm
Hello all,
We’ve had our Bongo for a few years now, she’s a 2.5D camper. Last year she dumped all her coolant and I replaced a few hoses and bled the system etc. Everything seemed Ok but she kept loosing a little water but I couldn’t find a leak. Eventually I tracked it down to the water pump and bought a replacement... Fast forward 8 months and I finally got around to replacing the pump and thermostat. Put everything back together and the battery was flat... Charged it overnight and now she turns over but doesn’t start!
I know how to hold a spanner but need some help diagnosing the problem (happy to be treated like an idiot). Or maybe there is an Essex based mobile mechanic who knows their way around a Bongo that you could recommend?
Many thanks,
DB.
Gertie
Re: Bongo not starting
Post by Gertie » Sun Jun 10, 2018 3:51 pm
During the 8 months mentioned above she was out of action and sitting on the drive. When trying to start there is a buzzing coming from under the drives seat...don’t remember this from before.
Not sure if this helps with the diagnosis but thought I’d mention it.
Post by Ian » Sun Jun 10, 2018 5:16 pm
It's possible that the fuel has evaporated and caused a blockage in the banjo filter or fuel filter.
Gertie
Post by Gertie » Sun Jun 10, 2018 5:26 pm
Excellent, thank you. Just googled that and have some instructions. Will try later this week.
DB.
Markas
Post by Markas » Sun Jun 10, 2018 7:08 pm
It's also possible that if there was a 'bio' element in the diesel it has caused algae to form and clog up the system while the van's been left standing.
Mark
teenmal
Post by teenmal » Sun Jun 10, 2018 11:58 pm
Gertie wrote: Sun Jun 10, 2018 3:51 pm During the 8 months mentioned above she was out of action and sitting on the drive. When trying to start there is a buzzing coming from under the drives seat...don’t remember this from before.
Does the engine turn over when you hear the buzzing noise, the buzzing could be dirty / loose starter cable. But please be careful when you go the check it incase you have a HIVE.
Post by mikeonb4c » Mon Jun 11, 2018 8:32 am
Mine often buzzes a bit when i turn ignition key to glow plug light on position. Not sure if its fuel pump or glow plug relay related but fancy its the former. Perhaps a techie on here could advise. I wonder if you have an airlock due to fuel draining back towards the tank through lack of use. Was the Bongo parked facing up a slope?
