Replaced mazda bongo autobox but got no drive help please?
wrightcustomvans
Post by wrightcustomvans » Sat Jun 10, 2017 8:58 pm
The clutches in my old gearbox burnt out, so I purchased a known good one with 6 months warranty from a Japanese breaker, I installed it with my torque converter, cleaned filter and replaced fluid with new, but I got no drive what so ever, have I done something wrong wondering if it's something to do with the torque converter
Re: Replaced mazda bongo autobox but got no drive help please?
Post by Northern Bongolow » Sat Jun 10, 2017 10:23 pm
did you check the oil level after fitting with the engine running, if you dip it with the engine not running all the gearbox oil is still in the sump and not necessarily in the torque converter and gearbox and oil cooler pipework.
just an idea but did it come with a matching ecu, not sure if they are matched but i know there seems to a lot of different gearbox serial numbers.
wrightcustomvans
Post by wrightcustomvans » Sat Jun 10, 2017 10:34 pm
I did check the fluid levels and were spot on, have not changed transmission ecu's did not realise you had to, just wondering if there is a special way of fitting a torque converter to one of these, eg do you have to pre fill the converter? Does it just slot in?
Post by Northern Bongolow » Sat Jun 10, 2017 10:54 pm
im not sure myself, im just chucking things out there.
Bongolia
Post by Bongolia » Sat Jun 10, 2017 11:58 pm
wrightcustomvans wrote:The clutches in my old gearbox burnt out, so I purchased a known good one with 6 months warranty from a Japanese breaker, I installed it with my torque converter, cleaned filter and replaced fluid with new, but I got no drive what so ever, have I done something wrong wondering if it's something to do with the torque converter
Did you unbolt the torque converter from the flex plate and remove it with the box or did you leave your old converter attached to the plate?
wrightcustomvans
Post by wrightcustomvans » Sun Jun 11, 2017 12:00 am
Yes unbolted and removed with the box then bolted torque converter back up and then slotted gearbox back on
Alacrity
Post by Alacrity » Thu Jun 29, 2017 5:13 pm
wrightcustomvans wrote:Yes unbolted and removed with the box then bolted torque converter back up and then slotted gearbox back on
Then you have quite possibly smashed the pump when fitting it. The converter must ALWAYS be fully installed into the gearbox BEFORE fitting to the engine. A quick measure to ensure the converter is sitting deeper than the flexplate on the engine is proud will confirm it is fully home.
A quick check is to dip the oil without the engine running & note the level, start the engine & dip it again. The level should have dropped considerably. If it hasn't then the pump & possibly coverter is goosed I'm afraid.
bongovi
Post by bongovi » Fri May 04, 2018 11:17 am
This is good info, thanks Alacrity. Did you (wrightcustomvans) ever get around to fixing this or figuring it out?
Looking at new gearboxes here as our van not getting up through the gears, getting no fault codes. There's a thread about it already (https://igmaynard.co.uk/bongo/forum/vie ... es#p700782).
  • 1996 AFT Bongo, black
    110AH leisure batt., 1KW PSW inverter
    Diesel heater, 100W Solar
