Abs sensor
sotal
Abs sensor
Post by sotal » Wed Mar 21, 2018 7:53 am
I still haven't sorted the abs sensor. :roll:
One quick question...
Will an offside sensor work on the nearside?
They are down as slightly different part numbers but I'm guessing the sensor will be the same? Perhaps just different mounts on it to suit that side?
My only worry was whether the sensor would be orientated any differently but I can imagine it would be.
I guess the cable length could be different too. However the nearside would if anything be shorter so that should be ok. The resistance on working ones is the same and it is only a very simple device.
What do you reckon?
TheLongRoad
Re: Abs sensor
Post by TheLongRoad » Wed Mar 21, 2018 9:29 am
Can't help with using one meant for the opposite side, but did you have no luck with any of the breakers? There seems to be quite a few being broken around the country.
2002 Friendee 2.0 ltr Petrol.
Re: Abs sensor
Post by g8dhe » Wed Mar 21, 2018 10:27 am
Almost certainly provided the sensor can be removed from the support of course.
Billybongo123
Re: Abs sensor
Post by Billybongo123 » Wed Mar 21, 2018 7:29 pm
If wires are a different length, just extend them dude
We love our rusty Bongo "Billy", despite his many faults!
sotal
Re: Abs sensor
Post by sotal » Wed Mar 21, 2018 9:19 pm
I've ordered it, fingers crossed it will be fully functioning again soon!
sotal
Re: Abs sensor
Post by sotal » Sat Mar 24, 2018 5:25 pm
All sorted.
The brackets are easy enough to remove, I just used a big screwdriver to lever them up. No real danger of damaging the cable as they have rubber around them where they go through the brackets.
So swapped the brackets over to the new sensor.
Cleaned up the new sensor ready to go in.
Found that the cable was too short. So cut down the old cable to make an extension piece.
New sensor wouldn't fit in the hole, so used a Dremel sanding drum to clean out the inside of the hole until it dropped in easily.
Bolted everything together and just been for a test drive.
So if anyone needs to know for the future...
The offside and nearside sensors are more or less the same. The nearside is shorter by a good 6" or so. The brackets swap over easily enough and the rubber bits are in the correct place for the correct brackets.
Saved me a good bit of money, still horrendously expensive for what it is though!
sotal
Re: Abs sensor
Post by sotal » Sat Mar 24, 2018 5:29 pm
Image Image Image Image
sotal
Re: Abs sensor
Post by sotal » Sun Mar 25, 2018 6:19 pm
2 hour round trip today and all perfect. :D
Re: Abs sensor
Post by Bob » Sun Mar 25, 2018 6:34 pm
Sound. 8)
