New here
New here
Hi Im new here.
I dont have a bongo yet but Im looking. Im thinking of a none converted vehicle and doing the conversion myself to keep the cost down nothing to flashy though. Im hoping to get lots of buying tips and conversion tips. I have checked out the buying section on the website so I have a bit of a start. Im looking to spend around £4000.00 on a van and £1000.00 to £1500.00 to convert it
Re: New here
Welcome aboard, good plan.
Re: New here
Welcome and happy hunting. Sounds v doable - just make sure you ensure you get a sound base vehicle.
Re: New here
Hello
Sound advice from Mike and Bob , a good base bus is the key , look out for rust and budget for coolant system servicing if there is no evidence of it being done . Otherwise they are a simple reliable bus .
best of luck with your search and keep us informed
Brian
Brian
Re: New here
Thanks for the feed back its just what I need at this stage. I here a lot about cooling and coolant. What should I be looking out for and is it just diesels? Stuart.
Re: New here
Diesels are the one to watch as if overheated they are prone to cracking heads or blowing head gasket. But many have had no problem at all. They all have ageing coolant systems and some metal pipes that corrode though and no engine likes being run without coolant so preventative inspection and replacement is the key.Stuie900 wrote: Tue Oct 17, 2017 7:39 pm Hi
Re: New here
And use a Bongo Friendly garage for any work on the cooling system.
Far too many stories of cracked heads start with a someone who knows better that the guys on here.
The 2 ltr petrol is like any other vehicle regards cooling system, and the V6 must be bled properly but is less prone to cracked heads.
Re: New here
Mike and Bob are correct .
The cooling system is getting old now so is bound to be starting to give problems , get a GOOD bongo savy garage to completely assess the state of the entire system and replace anything that looks dodgy . I replaced all the components but my bus is old (95) and I'm a bit OCD when it comes to that sort of thing
If you look up coolant system service on here you'll see my posts on it .
I got most of the replacement parts from Ian in the club shop , i feel i got a really good deal
Best of luck with your search
Brian
Brian
Re: New here
Welcome Tankak and happy hunting, or have you bought already?
Re: New here
And welcome from us.
