Removing the side door panel?
mitchelln
Post by mitchelln » Mon Sep 18, 2017 1:23 pm
Hi.
I want to take off the door card of the side door to fit insulation. Does anyone know how I get the inside door handle off?
Does it just pry off?
Thanks!
Black Aero City Runner 2L petrol with full side conversion
teenmal
Re: Removing the side door panel?
Post by teenmal » Mon Sep 18, 2017 1:48 pm
Here you go,this shows all clips etc....
http://lushprojects.com/bongopartsmk2/c ... o=.html#17
Post by Northern Bongolow » Mon Sep 18, 2017 2:17 pm
lean on the panel around the handle and look behind, its a horse shoe clip, get a thin screwdriver and hook it off then full the handle off the splines.
mitchelln
Post by mitchelln » Mon Sep 18, 2017 3:09 pm
Great! Thank you :)
Markas
Post by Markas » Mon Sep 18, 2017 5:48 pm
That reminds me, I've been intending to ask how to remove the side door 'L shaped' window surround since I noticed it flapping around during the summer hols. Should it be held on several spring clips? At least two have fallen out of that area since I've had the van :?
It's not shown on the same parts book diagram.
Mark
Post by g8dhe » Mon Sep 18, 2017 7:08 pm
Yes and some very odd shaped square ones as well on the ones below the window!
http://bit.ly/2jCMXHV
http://bit.ly/2jDA9RK
Post by Northern Bongolow » Tue Sep 19, 2017 1:37 am
on the L shaped panel there is a spacer type stand off piece as well as the clips, this is the bit the bit that will have broken off, so now clips wont ness fix it im afraid.
Markas
Post by Markas » Tue Sep 19, 2017 7:18 pm
Northern Bongolow wrote:on the L shaped panel there is a spacer type stand off piece as well as the clips, this is the bit the bit that will have broken off, so now clips wont ness fix it im afraid.
Is the spacer part of the original L panel molding or separate? I'm sure if it's just a spacer that's needed I can fabricate something and bond it to the L panel using an epoxy adhesive.
Thank you all for your help & advice :)
Mark
Post by Northern Bongolow » Wed Sep 20, 2017 4:18 am
its part of the panel, i did what you are suggesting on mine for a year or 2 until the squeaking repair finally drove me mad so i replaced it. :shock: .
Markas
Post by Markas » Sun Sep 24, 2017 8:23 pm
Northern Bongolow wrote:its part of the panel, i did what you are suggesting on mine for a year or 2 until the squeaking repair finally drove me mad so i replaced it. :shock: .
No squeaks from that area at the moment so perhaps I'd be best to leave it well alone. Or perhaps I can't hear it over the cups, pans and cutlery rattling around :D
Mark
