Hi all, Running Mazda RX8 Wheels, has anyone tried fitting one of these in place of the space saver spare?
Came out to check the van and to my horror had a puncture in the sidewall on the day before a early morning booked ferry to the Isle of White! Nowhere could I get hold of a replacement tyre needed the same day, but lucky for me I managed to find someone who would repair it for me.
After this little scare I would like to carry a proper spare!
Mazda RX8 Spare wheel
Mark Norton
- Bongonaut
Re: Mazda RX8 Spare wheel
I run RX8 alloys and keep a full size steel wheel as a spare. I made sure the rolling diameter is the same, despite the wheel itself being smaller than the RX8. Obviously the tyre width is slightly different, so not perfect, but better than a space saver and cheaper than having a spare alloy underneath the van.
You can use a tyre size calculator like this one to check rolling circumference:
https://tiresize.com/tyre-size-calculator/
This is vital on a 4wd or you will cobble the transmission, not that vital on a 2wd.
I'm not sure about repairing a sidewall puncture.
A full size spare will certainly fit on the bracket.
madbasshunter
- Apprentice Bongonaut
The RX8 alloys will fit as a spare as I replaced my spacesaver with one the other day
as I have a spare set of alloys lying around.
madbasshunter
Pictures of it in place
https://drive.google.com/file/d/0BzNbtp ... p=drivesdk
This is with a 245/45/18
