Hi All
Old question but have a 2.0ltr and it needs new coolant.
Is it just a case of taking radiator plug/hose out flushing through and filling up. Or is it more complicated like the diesel.
Thanks frank
coolant change
- Bongonaut
coolant change
A smile is a small curve that straightens everything out
Re: coolant change
Yes as you say,plus it might be worthwhile using a rad flush type of treatment and check condition of All hoses before you fill with new antifreeze.
Good Luck.
Good Luck.
- Bongonaut
Re: coolant change
Thanks I'll do it tomorrowonce i've got some rad flush.
Thanks again
Thanks again
