erratic dashboard
jasonh1967
erratic dashboard
Post by jasonh1967 » Fri Aug 04, 2017 11:27 am
ive had a look through forum to see if any thread on my problem but I cant see it...so apologies if it has been already discussed here. My 2.5 manual N reg bongo has an ongoing dashboard problem. The speedometer and rev counter can be very erratic and flick about all over the place. For years this was just an occasional problem but now it happens pretty much all the time and after flicking around for a bit will just stop altogether and stay at 0. Very occasionally they will give a truer reading but it doesnt last for long before the flicking and or stopping happens. Also the temp guage registers as constantly overheating...even though it isnt overheating and i have had extensive research done on this by a mechanic. The fuel guage is always accurate. Anybody any ideas. My bongo has been a very good runner but I have had a number of electrical issues. Thanks
nth
Re: erratic dashboard
Post by nth » Fri Aug 04, 2017 11:41 am
Do you have a speedo chip fitted ? I was having similar problems when I first got my Bongo that had a converted speedo. I removed the speedo chip & fitted an overlay instead & never had another problem with it.
95 2.5d 4WD AFT
teenmal
Post by teenmal » Fri Aug 04, 2017 11:47 am
Might also be worthwhile checking the plugs/wiring on the back of the instrument cluster are clean and secure .
Post by Northern Bongolow » Fri Aug 04, 2017 7:05 pm
or the alternator is packing up, admittedly, very slowly. check the voltage out of the alternator through the rev range, make sure it rises with revs etc.
jasonh1967
Post by jasonh1967 » Sat Aug 05, 2017 10:10 am
Thanks for the advice, appreciate it. Speedo chip sounds a real possibility :D
Post by g8dhe » Sat Aug 05, 2017 12:28 pm
The Speedo chip shouldn't affect the RPM, different sensors, however all the gauges use a common earth connection other than the fuel gauge, so check the connectors and the common earth!
jasonh1967
Post by jasonh1967 » Mon Aug 07, 2017 10:55 am
thanks for all the advice :D
cmm303
Post by cmm303 » Sat Aug 12, 2017 10:23 am
jasonh1967 wrote:thanks for all the advice :D
Do come back and let us know what sorts it. Solutions are good :idea:. :D
Chris with BertieB
