Centre cubby hole cover
Moderator: Ian
- the1andonly
- Tribal Elder
Could have been any time in the last 5 years some one posted a template of a cover for the centre consul hole.
I cant find it, help!
Re: Centre cubby hole cover
jaylee was good at this stuff, search for jaylee,s posts.
http://igmaynard.co.uk/bongo/forum/view ... er#p482076.
or you could search your names posts and find this one.
http://igmaynard.co.uk/bongo/forum/view ... er#p677082
- the1andonly
- Tribal Elder
senility?
I don't remember that
its not just you, i do it all the time.
Sorry - do what?Northern Bongolow wrote:its not just you, i do it all the time.
- the1andonly
- Tribal Elder
My sincerest thanks to Tangle foot.
Used the template to make different magnifications to partition the cubby.
electronics and a display behind, in front a shorter glory hole. phone and a 3 way12V usb extension.
Currently in shed awaiting a second coat of primer.
- the1andonly
- Tribal Elder
What a surprise I forgot to thank NB
- the1andonly
- Tribal Elder
will do if photobucket or what ever is the new method of adding pickys allows me to.Northern Bongolow wrote:![]()
. please remember to show us all what you have done when its finished, sounds interesting.
- the1andonly
- Tribal Elder
simple piece of ply wood (up-cycled toy form-house) satin black spray paint
checked paper template, was a little narroer so made a wider part then took one resize to fit where required (ish) perfect enough for me
and more importantly swmbo
required hole in side of glory hole to pass usb cable out. used to power arduino and allow reprogramming/ dowloading of data from the sdcard
warning led on rhs of display. usb powered from the double supplies seen here before (ignition on piggyback fuse)
what did he just say.
, anyone translate.. wood bit looks good.
