Replacement Arches & Decals ??
martinc
Re: Replacement Arches & Decals ??
Post by martinc » Tue May 10, 2016 1:06 am
cheers cmm303 will send him a PM pronto.
Martin
Post by mikeonb4c » Tue May 10, 2016 8:13 am
martinc wrote:
cmm303 wrote:
martinc wrote:hopefully it goes smoothly !
but where is the best place to get some replacement arches to weld in instead of grinding away rust ?
cheers
got my sprinter arches from member called Kloonsy
ahhh ok , do you know if he/she is still active .
thanks
Kloonsy (Dave) still active. I was over there a couple of weeks back to discuss possible work on mine.
dom_e
Post by dom_e » Tue May 10, 2016 6:48 pm
cmm303 - I filled that little gap with some custom designed and 3D printed sections, which I then bonded on. That works well. I used an expensive process at work (then hand finished and sprayed to match), but I could offer to do it on my home 3D printer in a generic silver material if you're interested.
Beyond A to B
cmm303
Post by cmm303 » Tue May 10, 2016 10:01 pm
dom_e wrote:cmm303 - I filled that little gap with some custom designed and 3D printed sections, which I then bonded on. That works well. I used an expensive process at work (then hand finished and sprayed to match), but I could offer to do it on my home 3D printer in a generic silver material if you're interested.
That is a kind offer. It does not fuss me too much and it is now apparent that my bodyshop didn't too good a job with some of the metal work above the bumper which is now bubbling so I need to get that sorted this summer.
Chris with BertieB
rita
Post by rita » Wed May 11, 2016 6:50 am
Martinc,this might help you.
http://www.ebay.co.uk/itm/MERCEDES-SPRI ... 19f4eec375
Good Luck.
cmm303
Post by cmm303 » Wed May 11, 2016 8:08 am
rita wrote:Martinc,this might help you.
Good Luck.
good price! Not sure how you check the quality.
Chris with BertieB
rita
Post by rita » Wed May 11, 2016 10:01 am
cmm303 , Just in the process of fitting a pair, they weld ok and the extra that you cut off can be used to fill in inner structure etc, they need to be split and a 25 mm infill used in order for them to fill the complete arch profile.
Good Luck.
martinc
Post by martinc » Wed May 11, 2016 9:38 pm
Thanks rita for that link , they seem very cheap and hopefully they are of a decent quality .
Martin
llitvack
Post by llitvack » Sat Jul 01, 2017 8:54 am
Hi folks.
I'm getting my rear arches replaced, and was wondering if the Mercedes Sprinter mark 1 (1995-2006) was still considered the best option? I believe from this thread that the replacement needs to be cut and widens with a spacer.
What about this one, from Mazdabongo.com:
http://mazdabongo.com/catalog/new-mazda ... ll-models/
Or this one, from Bongospares:
http://www.bongospares.co.uk/shop/body/ ... s-pair-of/
Do they need to be cut and widened?
Thanks in advance from Leon
rita
Post by rita » Sat Jul 01, 2017 9:02 am
They look like Sprinter Arches, by cutting the arches it actually makes them easier to fit and weld also welding in the fillet makes them stronger .
Bongolia
Post by Bongolia » Sun Jul 02, 2017 6:06 pm
I use these, they are a lot cheaper and the steel quality is good.
http://www.ebay.co.uk/itm/MERCEDES-SPRI ... Sw-CpYBQrW
This covers where to make the cut and align the arch. The offside is not so important unless you have an Aero kit fitted.
http://igmaynard.co.uk/bongo/forum/view ... 90#p685524
