Fuel Filter Stuck
- Apprentice Bongonaut
Fuel Filter Stuck
Happily done all the other bits of a service. But the fuel filter is well and truly stuck. Any one got any tips? Please?
Hmm... i know that if the oil filter is stuck, you can pierce it with a long screwdriver, and get a turn on it that way, I wouldnt reccomend that method with the fuel filter though!
Perhaps you could use one of those chain clamp oil filter removal tools on it though? They just squash it a bit, but get a good grip, they actually tighten their grip the more effort you use, they should be available from any decent motor factors...or maybe even halfords. good luck
When I changed mine, I was puzzled by the electrical plug connected to the water thingy under the filter - I was expecting the loom end to be attached to the chassis, allowing the sensor end to be unplugged - but for some strange reason it was the other way round, so you need to release the connector from the chassis - unplug it - unscrew the water trap thingy from the bottom of the filter, with a container under to catch any liquid - then you can just get a small chain-type wrench on it. They must tighten with age - mine took some shifting!
Mike
Mike
The trouble is most people are ill advised that with oil and fuel filters you need to tighten them murder tight. They only need to be tightened by hand, trust me I have changed many hundreds of them, not specifically Bongo's I admit.
The screwdriver option is one I've used but just make sure you have the correct replacement filters to hand before committing yourselves and stuffing a screwdriver through the filter.
