Your advice and experience is much appreciated.
Thank you
You lose the winter quick warm up capability. If it isn't currently working then you lose nothing and there is less to go wrong (the winter valve has been known to jam in the start-up position).MissBerylBongoTattoo wrote:Brilliant thank you Gasy. Can you confirm if the 3 part is better than the 4 part? or does it make no difference?
