1995 Bongo 2.5TD AUTO 4wd gearbox coolant pipes
Hi, new to bongo-ing, and hope someone can help, where can I get new/used working coolant pipes, reverse has gone and I'm being told they don't exist anymore, is this true, I really hope someone can help me...thanks.
Re: 1995 Bongo 2.5TD AUTO 4wd gearbox coolant pipes
Maybe Bongo shop has them?
Do you mean these
BV80199A0A 199A0 PIPE,OIL-OILPUMP
You could just replace them with rubber hose of the correct type and diameter.
When you say your reverse has gone do you mean you cannot select Reverse gear?
Do you mean these
is this the pipes you require..Klewis wrote:Hi, new to bongo-ing, and hope someone can help, where can I get new/used working coolant pipes, reverse has gone and I'm being told they don't exist anymore, is this true, I really hope someone can help me...thanks.
http://bongoland.co.uk/product/atf-pipe ... ol-bongos/
I can select reverse it just doesn't do anything, a mechanic had previously replaced the coolant pipes with rubber pipes but it seems like it's a temporary solution, it drives forward perfectly well, thanks for replying.
K
K
If it drives in forward gears but not in reverse
I don't think new pipes will fix it
I just cut off my bad bit of pipe and replaced with rubber hose
I'd check the fluid level before doing much else.
Hot, engine running, and cycle through the gears a few times before using dip stick.
Its just possible some was lost when the pipes were changed and not topped up.
Thanks I'll look into it
If it's the rubber link pipes that you're after, they are still available from Mazda 19-9E0 and 19-9D1 here http://lushprojects.com/bongoparts/page ... esel).html
I can't see that losing reverse has anything to do with the condition of any of the pipework to the oil cooler though unless they are split and your oil has all gone. Bob's suggestion that you check the level is the place to start. If the level is ok then look at the linkage between the selector and the box to make sure all is moving as it should. if that's ok then it could be the selector switch on the side of the box could be at fault, past that you're looking for specialist help.
http://igmaynard.co.uk/bongo/forum/view ... ox#p509775
This may be of some use relates to no reverse.
Check your levels and selector first if OK find an ATX guy.
