Starting problems
Barrypud
Starting problems
Post by Barrypud » Fri Apr 28, 2017 2:42 pm
Just recently I have had difficulty starting my bongo after a short journey. My mechanic says that the fuel pump seems fine and he didn't have a problem with starting up but could be an intermittent problem. Today after a short journey I couldn't get my bongo to start but the engine turned over fine. I waited for about 20 minutes and tried again. This time the engine just about fired with lots of smoke and with some hefty revving I managed to get away and back home. I had a recon pump fitted 8 months ago but as I said the mechanic says this seems to be working fine.Any suggestions would be appreciated before I ask the garage to take another look.
Quick update - engine turns but will not fire at all,
Re: Starting problems
Post by Bob » Fri Apr 28, 2017 3:02 pm
Which engine do you have?
Barrypud
Post by Barrypud » Fri Apr 28, 2017 3:23 pm
2.5TD 1995
Barrypud
Post by Barrypud » Sat Apr 29, 2017 7:52 am
Started first time this morning but I'm now afraid it will play up again when I take it out!
Post by Northern Bongolow » Sat Apr 29, 2017 8:16 pm
this type of non starting on diesels when warm could be the tank cap / tank breather blocked. to test try running round as normal but with the cap fairly loose or even off, or fit one of the cheap push fit replacement caps available from car shop and petrol stations. if the loose cap thing works come back and we can advise on unblocking the breather on the tank.
as the fuel tank empties it stops the fuel going to the pump so vacuums in the tank.
Tony x
Post by Tony x » Sat Apr 29, 2017 10:32 pm
We had a similar problem a few years back but that was just after fitting a new (and primed) fuel filter. Putting the old one back on sorted it. Thinking of the easiest and cheapest things first, then the fuel filter might be worth a look if the filler cap doesn't sort things.
Barrypud
Post by Barrypud » Mon May 01, 2017 6:25 am
Many thanks for your replies - I'll try the fuel cap suggestion first and then fuel filter. I should add that the difficulty starting seems to be primarily when the engine is not fully warmed although not exclusively. I have also had a couple of occasions recently when even after starting easily from cold the engine has needed to be revved to keep it from cutting out. Whenever these things happen there is always a lot of smoke until the engine settles down. I'm not mechanically savvy so anything other than basic things I will need to ask my mechanic to check. Once again - I appreciate all the help you can offer.
Gasy
Post by Gasy » Mon May 01, 2017 8:12 am
Worth cleaning the banjos filter aswell
Barrypud
Post by Barrypud » Mon May 01, 2017 8:20 am
Thanks Gasy - not sure what that is but I'll ask my mechanic!
Bongolia
Post by Bongolia » Mon May 01, 2017 10:34 am
Gasy wrote:Worth cleaning the banjos filter aswell
Is this banjo filter the banjo on the pump body?
wonkanoby
Post by wonkanoby » Mon May 01, 2017 10:47 am
yes it is
Barrypud
Post by Barrypud » Mon May 01, 2017 11:40 am
Would this have been supplied as part of the the recom pump I had fitted or is it a separate item?
wonkanoby
Post by wonkanoby » Mon May 01, 2017 12:04 pm
its part of pump
wonkanoby
Post by wonkanoby » Mon May 01, 2017 12:10 pm
Barrypud
Post by Barrypud » Mon May 01, 2017 12:59 pm
Many thanks for the pic - I'll update after my mechanic has taken a look.
