Gas hob
Moderator: Doone
Dave218
Gas hob
Post by Dave218 » Sat Mar 04, 2017 3:04 pm
Well Beryl has arrived, but I haven't a clue how anything works! Sat on the drive dying to make a brew and can't get the burners on, can't even locate a gas bottle ( if it has one) only what appears like an adapter on the outside? Is this the norm,do I have to put my gas bottle outside, help please my fellow bongonaughts :roll:
Bongolia
Re: Gas hob
Post by Bongolia » Sat Mar 04, 2017 3:33 pm
Congrats on getting the Bongo.
Is it a side conversion?
Bottle(s) are normally in the wardrobe bit.
I would imagine the outside gas thingy is for an outside barby or something any chance of an image of the offending item?
You may be able to trace back from that pipe to the bottle.
Re: Gas hob
Post by g8dhe » Sat Mar 04, 2017 3:45 pm
Open the rear door, and look down the lower right corner often a small hatch behind which is the mounting for a gas bottle ?
Dave218
Re: Gas hob
Post by Dave218 » Sat Mar 04, 2017 3:54 pm
Only a fuse box in that cupboard,, it's also an lpg conversion if that matters,,,
Re: Gas hob
Post by g8dhe » Sat Mar 04, 2017 3:57 pm
Perhaps some pictures then, the trouble is everyone can be a bit different depending on what was wanted at the time!
TheHillsAreCalling
Re: Gas hob
Post by TheHillsAreCalling » Mon Mar 13, 2017 5:02 pm
Don;t know much about your conversion, but in my side-conversion it's under the unit immediately behind the drivers seat - Standing outside the drivers door I fold the seat forward to access it.
Good luck, and enjoy the Bongo.
Dave218
Re: Gas hob
Post by Dave218 » Tue Mar 14, 2017 12:28 am
Thanks everyone for the advice,, think I've sussed it with some advice from a VW colleague at work,, will keep you posted on the end results
Re: Gas hob
Post by Bob » Tue Mar 14, 2017 1:29 am
Good news. :D
Updates always welcome as info helps others. :wink:
Dave218
Re: Gas hob
Post by Dave218 » Tue Mar 14, 2017 12:43 pm
Sat having a brew even as we speak, what I thought of as technical difficulties I've been assured is only a learning curve! :-)
Just to sort the leisure battery situation, how to fasten the awning, wait for the wife to 'decorate' and the upstairs mattress to arrive and I think Bob might just be my uncle
Re: Gas hob
Post by Bob » Tue Mar 14, 2017 5:48 pm
:shock:
Bongolia
Re: Gas hob
Post by Bongolia » Tue Mar 14, 2017 6:14 pm
Bob wrote::shock:
Bob must have had a bike cos he is quite a lot of peoples uncle. :shock:
Re: Gas hob
Post by Bob » Tue Mar 14, 2017 8:41 pm
Still have several. :lol:
